1/4", 3/8", 1/2" socket wrenches and 8mm, 10mm, 12mm, 14mm, 17mm, 24mm, Screwdrivers, socket extensions, Channel locks. I would make sure you carry a seperate container for just fluids (brake fluid, coolant, oil, chain lube, filter cleaner, grip glue (crazy but I have had to use it twice). Thhe bike doesn't take a ton of tools to work on it but it does take multiple tools on the same nut and bolt. What I am getting at is don't take 1-12mm socket, you might need another 12mm to hold the bolt end or something. Take a good look at your bike and figure out what wrenches, sockets you would nee to take it apart and take them with you. I have a homedepot special rolling tool chest that is 30" long by 18" wide and 2' tall and it works perfect to take in the truck with the quad for a little weekend warrior riding.
