That's pretty much the exact reasons I want one.I had a local garage weld a receiver on mine and it works great. I used it to pull my trailer out of my backyard, for yardwork if needed and to hook a tow line to it. Let me know if you wanna see pics
You'll burn up your clutches....
IMO it will suck for yardwork unless you have a huge yard. Having the added weight of the trailer on the rear will only give it more grip and a wider turning radius. It will also really mess up your grass.I see conflicting views here on this but I think I will order a hitch for my 700xx. (Looking at the Quadboss at 4wheelonline.com)
Main reason for this is rare light yard work. Would hooking up a light plastic 12 cu ft poly cart to move mulch or some firewood really hurt this machine? Would lower gearing help ease the wear and tear? I have already ordered and planned to install a 13 tooth sprocket.
Thanks for the reply. But could you explain the logic please. What does the size of the yard have to do with the machine's ability to tow a light load occassionally? As far as the grass, I am not looking to hammer the throttle through my lawn so how would the effect be worse than that or driving a car over the lawn occassionally?IMO it will suck for yardwork unless you have a huge yard. Having the added weight of the trailer on the rear will only give it more grip and a wider turning radius. It will also really mess up your grass.
Just my opinion....
