so i went out riding around the farm on sunday and was cruising i went to shift into fourth and noticed my shifter was stuck up and and would not go past fourth and had no tension to return itself back to position, i read a couple of forums and i found one that talked about a clip in the transmission that breaks and causes this, anybody else had this problem and is it simple to fix or does it need to go to the dealer if you are just a novice mechanic?
