I got the vapor on ebay. the way its mounted on the stock dash is custom. I cut out the hole for the fuel breather hose to run the wire through, and I drilled holes in the plastic and screwed them right into the screw holes on the back of the vapor. I screwed a little piece of plastic under the bottom to tilt it up a bit too.
