21 - 22 of 22 Posts
i had a look at fitting yfz 450 shocks tonight at the shop but they are alot shorter shock than the 700xx or the trx450,
but im glad i had a look at them as i noticed the rear yfz450 shock appears to bolt into the rear of the 700xx but im not sure if the spring rate will work, and also the resivours are both goin to be on the same side which will look odd and make adjustments a bit difficult,
i will fit them tomorrow hopefully though and see how i go with spring rate and ease of adjstability and let you all know how it is
Like some pics ,if possible. I may need to go lower.
Discussion Starter · #22 · (Edited)
not i will get some more up tomorrow
with the yfz rears and better ones of the fronts,
21 - 22 of 22 Posts
