It didn't solve the problem I was trying to get rid of but I do like it. It is still to sensitive and needs more resistance when you twist it. Not sure what if anything I can do to stiffen up the twist a little. Would be nice if Motion Pro would put some type of adjustment on it. The other thing I ran into and not sure if there is a fix is that on the twist side, you can not use the screw and cover at the end of the grip. It binds the end of it and won't let it twist. Maybe there is a way to incorporate that into something that to put a little resistance on it. Anyway, I think it was a good move to get rid of the thumb thingy.
The instructions say to lube the cable before installing. I used a cable lube but I also have a can of lube with teflon and is a gel consistency. If you spray some on your fingers, it has a sticky touch to it. I was hesitant to use it, not knowing if it would be too sticky and bind the cable. I have thought about taking it back off and giving it a try but not sure if I could wash it out if it did not work out. Any ideas? Thanks
