bars were on it when i bought it. pretty sure you can find them on ebay. i know i found them with a google search. not cheap though, £275 over here.Where's you get your bars at???
I need those tires for the dyno!
terrycable throttle is really good. you can lock the twist part and just use the thumb. there's a button under the housing, push in and it's locked, pull out and it's twisty. the housing is quite a bit bigger than the stock one, but it looks a hell of a lot better and works great.:tup:How do you like the Terrycable throttle?
I'm thinking about getting one.
Can you lock the twist part when using the thumb part?
i didn't know you're not allowed to take them on the road over there. it used to be a bit of a grey area over here until those nutters in brussels started to get involved in our laws. one of the only good things they've done!!That is VERY cool, nice quad! I wish we could ride on the streets over here!
acewell. they do a few different ones. mines a 3000 model iirc. all the standard lights (engine management, neutral, turn signal, oil etc) have been wired in . very neat. also has rev counter too.what kind of dashboard do you have? Looks like nice large display.
I'd go everywhere on mine lol.That is VERY cool, nice quad! I wish we could ride on the streets over here!
you get everything you need with the kit, (it's only a speed sensor) just glue the magnet to the front wheel and follow the instructions. not too sure how the rev counter works, it's not great tbh, but it kinda works. i think everything else is just a rewire of the original dash lights. check out their websitebaldydaz,
Did you install the gauge pod on your machine? If so, was it a big job installing the sensors and miscellaneous wiring? Sure wish they installed this item at the factory. The manuals talk about maintenance time/hours and etc. but no way to check it. I put on one those simple running time meters and am somewhat satisfied with it. Thanks for the pictures.
Sid
