What is your real front and rear width now with your set-up?
I have read an article about solid axle bike and they said that if the rear is narrower it tends to be more prone to slide and this not they want but for an irs bike it change the things positively.:yay:
my fronts are now 3+2. Yes it makes the bike wider, but with the added camber up front also i was able to go into corners much faster. I can turn good on dunes , Had video..but my friend the camera operator did not operate the camera very good. Plus the 3+2 fronts helped with the 4+3 rear paddles.
Everywhere i ride and all the things i do i felt that front offset was best for me. and so far it is.
Also note that i got the Sonic rear sway too..that too eliminated most of the front push.
Now i have said before on this forum that people need to throw out this thinking quad suspension and think Car. The SRA is a Oversteer generator...yes its fun to whip the back around...but can also be dangerous.
Options like Rear sway bars, Tire offsets, Tires and Spring rates/dampening...now allow you to tune the bike the way you want it.
