This weekend I change the oil and filter and did intall the filter the proper way (O ring out) and noticed when I start the engine, I can hear a winding noise coming from the clutch casing, the one behind where the oil filter casing is and it goes away about 30 seconds or when I pull the clutch in then the sound is gone for good. I know that I used the clutch quite a bit on the last ride especially feathering it due to the logs and boulders but it doesn't slip or anything when I have it in gear and engage the clutch....weird!!! Did not noticed the sound prior of the oil change since I was not really paying attention, the only reason I did this time is because I was inspecting for leaks. Any suggestions?
Thanks
Thanks
