i say you wait about a month and by the Alba kit when they release it... top of the line products and not pricey like some other brands... I've used their products on my other rides, and can't find a single thing to complain about... plus Matt will hook you up
Alba Kits are available. I installed mine last week and I am very pleased with it. I dropped it off at DynoJet today and I will be posting results tomorrow. As far as Exhausts go I am running the FMF Speed Slip-On It sounds great and realy opens up the 700XX over stock. I cant say if it is better or not over any other Slip-On because I have not seen any side by side compairisons. Matt at Alba has me on his waiting list for an Alba Full Exhaust that is in development and about to be released. I would bet it to be better than any other since they R&D with ther kit and Wayne Mattlock. The best programmer hands down is the Power Comander 5 especialy with its upgradeability (Auto Tune, Quick Shifter, and Map Selector). Here is a list of what I have now.
1) Stage 3 Desert & Endurance kit with the upgraded "hardened" rocker arms.
2) The head was ported and flowed with Alba's Superflow flow bench. The head port configuration included +1mm oversized intake valves as well as a
5-angle valve job.
3) Piston is forged and has an 11:1 compression ratio.
4) Camshaft with Alba custom grind specifically for the 700XX kit.
5) Valve spring kit with titanium retainers.
6) Throttle body taper-bored to 46mm.
7) Velocity Intake Kit
8) Power Commander V w/Auto Tune.
9) FMF Slip-on Speed Muffler.
I have on order order
Maxxis Razr 2 M933 23-7-10 for the front
Maxxis Razr M932 22-10-11 for the rear.
