I would like to know if anyone has had any luck with buying wider rear wheels, and if so what did you buy?
I am running ITP 10x7 rear rims which is a little wider than stock and I have ordered a set of OMF/DWT 10x8.I would like to know if anyone has had any luck with buying wider rear wheels, and if so what did you buy?
Baxter, any more info on these? I assume it is a Douglas wheel modified by OMF? What offset are they?and I have ordered a set of OMF/DWT 10x8.![]()
It is a Douglas 10x8 (4+4) 144 PCD fitted with OMF Beadlock.Baxter, any more info on these? I assume it is a Douglas wheel modified by OMF? What offset are they?
How width does it make your quad? I want those Hiper wheel madly I'm popping front and rear tire regulary.:steamed:And yes I'm running 6-7 psiwe run the Hiper Carbon Fiber beadlocks! great wheel and ITP Holeshot XCT 22-11-10
How long have you ran them on your quad?we run the Hiper Carbon Fiber beadlocks! great wheel and ITP Holeshot XCT 22-11-10
Hey Baxter, you said you're running a 4+4. Wouldn't that make your XX wider than using a 4+3? What does you XX width measure from the outside of one tire to the outside of the other? I believe stock I'm sitting at 46" and with my new set on the way I'll be at 50." Does this affect the XX's cornering ability?It is a Douglas 10x8 (4+4) 144 PCD fitted with OMF Beadlock.
OMF seems the only ones I have found that carry this rim. Originally going to put a beadlock on a set of 10"ITP's.
The DWT/OMF 10" should add 1/2 2 over the ITP.![]()
