atv dust mask
The Wolfsnout takes a bit to get used to just as any thing new you try. With a little patient and practice it can be very comfortable. First bend the top seam back and fourth to loosen it up a little. If you fold the top front tip down and to the right and the bottom tip up and to the left while giving a little twist you can compress the mask to fit under even a close fitting helmet. Also make sure you are putting the nose flap on correctly. With your helmet off touch the tip of the nose piece to the tip of your nose, push the mask in to your upper lip. Then you can see better how it fits .See video on the wolfsnout web site
This works well for thousands of people, but some helmets and faces are not compatible. If you still can't get it to work almost always the Wolfsnout All Sport will solve the problem. We still believe it is the best Atv dust mask on the market but if anyone is not satisfied you can send it back for a full refund or trade them in on the All Sport mask.
Also to the site administer if you would like I will send you one for a review on your site. Compare it to the other utv and atv dust masks.
