hey guys how is it goin? i just orderd a motorworks slip on,uni filter,and lexx efi controller from rocky mountain atv,i have two questions,you probably get these a lot,for the controler do you have to make adjustments to run it with an open air box?and with the uni filter does it replace stock filter basket?or do you have to still use it?cause my cousin was givin me crap about how i should of gotten a k&n filter.thanx guys!
Sponsored Links | |||
light weight durable stylish
mild overall power increase high torque increase bit if a tight fit instralling minor tweaking VERY LOUD 104DB+ |
Would you be able to post some pics or technical info on the system? Did you measure the sound or quessing? Not being d1ck just trying to get more info. If you have the pics just edit your original post to keep from spreading the info out
Had to make some minor tweaking with the EFI but keep it as is first and see how it runs. Depending on where you usually ride, the K&N would be good in trail area but if you're riding in a dusty area then I would recommend the UNI which is what I'm using and you do use the OEM basket. As for the open air box, again, depending on where you ride, I would suggest the EHS lid. This is what I use. Open air box is good if you're not riding in a muddy/watery trails.
(db meter at sand mt nevada) was where the 104 came from
(db meter at sand mt nevada) was where the 104 came from |
All I have to say is watch out for the sound gestapo here in California... they are everywhere. When I can gather some $$, I'm going to get the new HMF system. The money I have now is going for new shocks... ordering tomorrow.
yes now that ive let some of my friends ride it and for a spectator view i never realized it was that loud. i love it but do have to be carful here in ca. im lucky to have private property to ride on.
I have the FMF 4.1 w/Powerbomb header. The install was clean and easy. I also installed the FMF programmer. Sound is pretty loud without the 96db insert. The change in power was considerable. It has made the machine much more fun to ride. Here are a few pict's.
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
i didnt realize the stock heat shield would work with the powerbomb header!
On the 11th I'm taken my bike up to OCC so they can build me a mid pipe and some brackets for my Supertrapp, who knows, they might even build me a header for it then I'll just need to find a place that has a dyno machine so I can get my PCIII tune up
Sponsored Links | |
Thread Tools | |
Display Modes | |
Posting Rules | |
