Stock top speed checked with GPS - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 02-18-2010, 01:51 PM Thread Starter
Brokenbones's Avatar
OK, yesterday I made 3 run on a flat road, no wind.
I got a 14t sprocket
Uni filter
Modded airbox
Stock tire 3 psi
91 octane gasoline
So my top speed is 123km/h or 76.87mph
NOTE. My valves are not adjusted (Hey mecanics does that make such a diffence in your opinion?)
Also my Vapor shows 112 km/h (or 70mph) top speed and at 50km/h (or 31.25mph) and it's spot on with the gps???
Brokenbones is offline
post #2 of 18 Old 02-18-2010, 02:20 PM
Uni filter
Modded airbox
Stock tire 3 psi
91 octane gasoline
That seems about right, The big3 almost isn't enough to push the bike to the limiter at 87mph. You shouldn't have any valve issues, How many hours since you've last checked them?
post #3 of 18 Old 02-18-2010, 04:09 PM Thread Starter
Oh well I have not checked them yet since it's new... I'm about 30 hours now!
post #4 of 18 Old 02-18-2010, 04:57 PM
post #5 of 18 Old 02-18-2010, 05:50 PM
OzLinc's Avatar
Quads ahve a big problem with tire growth at speed, thats why your Vapor will always be wrong......at about 70kph the tire will start to grow all the way to 125kph+......it's a PITA.
Linc
OzLinc is offline
post #6 of 18 Old 02-18-2010, 05:54 PM
If you ever come back this way or if we make a ride together I can check them for you Scuzz.
post #7 of 18 Old 02-18-2010, 06:09 PM
post #8 of 18 Old 02-18-2010, 07:51 PM
phucknutz's Avatar
I need to check my valves too. I'm sure I'm over.
I will let you know when we reschedule the EHS trip, we will do them for you. come on out it will be a good time!
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #9 of 18 Old 02-18-2010, 08:43 PM Thread Starter
Does the valve clearance realy make a difference for overall performance?
post #10 of 18 Old 02-18-2010, 09:02 PM
Yes, Are you having problems to make you think they are out of spec or your just asking in general. There is nothing wrong with your top speed if you were thinking you should be getting more. The XX wont hit the rev limiter in 5th in stock form.
