Beware of this rear bumper from PRM - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 04-30-2010, 08:23 PM Thread Starter
So I recently purchased the control bumper from PRM (http://prm-atv.com/MN.asp?pg=product...=1856&from=115) and it doesn't fit with my exhaust. I have the FMF 4.1 full exhaust (It is bent up just a hair from someone hitting me). Anyway, when you try to put the bumper on, the exhaust wont be able to go up to it's rear mount, other wise it will hit the bottom of the "Baja" bar. Now I am sure you can jerry rig something up with the exhaust so that it hangs lower, but I don't really want to do that as they have it at the angle for a reason (matching up with the other pipe, no angles in it, better flow, which if bent a little down it wouldn't be). The bar itself looks awesome, is light weight, and looks like it would offer lots of protection, just the darn fitment probmel with the pipe. In the picture, they have it on the machine w/ a stock pipe, which is relatively shorter than mine. I am a little bummed....
post #2 of 10 Old 04-30-2010, 10:54 PM
Chuck
Have the same bar and basically had to trim the under grab bar so it could fit. Don't have any pictures of it but still does its job.
post #3 of 10 Old 04-30-2010, 11:14 PM
ill take it. but yeah try to trim it.
post #4 of 10 Old 05-01-2010, 02:42 AM
markas214's Avatar
What bumper are you using? I got a desertt II and the standard grab bar. PRM makes solid stuff.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
post #5 of 10 Old 05-01-2010, 09:07 AM
This was discussed in another thread before. If Search would only let three word searches happen hint hint admin.
post #6 of 10 Old 05-01-2010, 12:51 PM
Send a message via Yahoo to Robotaz
The saying is "jury rigged", not jerry rigged. Sorry, couldn't resist.
2008 Honda TRX700XX
2008 Yamaha Wolverine 350
Robotaz is offline
post #7 of 10 Old 05-01-2010, 03:49 PM
700xx crazy's Avatar
Huh never heard that, always "jerry rigged" thanks. Now i know how to say it not appear stupid.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #8 of 10 Old 05-01-2010, 11:14 PM Thread Starter
Um, I usually never us jerry, or jury, but another term, such as Blonde rigged, or something stupid along those lines. And I dont remember another thread on this one. I am using the exact bumper that I have posted in the link above. I have a PRM front bumper and skid plate, but just thought that this would work with an aftermarket exhaust as it says.
post #9 of 10 Old 05-02-2010, 06:08 PM
This was the thread I remembered
https://www.club700xx.com/vb/showthread.php?t=2075
post #10 of 10 Old 05-02-2010, 07:00 PM
aubfans's Avatar
I appreciate the info.
"Pretty good, is hard to beat."
aubfans is offline
