engine ice coolant - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 07-22-2010, 08:36 PM Thread Starter
engine ice coolant
i was riding last sunday it was about 95 out side the bike was smoking hot to the pooint where my leg was burning through my riding pants. so i ordered some engine ice coolantr from dennis kirk. fully flushed all the old coolant out, and filled her up with the ice. rode it hard for 30 mins no fan and it was hot but not unbearable. the true test will be this weekend ride its going to be 100
graysuperduty is offline
post #2 of 4 Old 07-22-2010, 09:06 PM
USMC0861's Avatar
Its great stuff!! I run it in my Vmax and it runs alot cooler also my buddy runs it in his z1000 and runs consistently 18-20 cooler.
USMC0861 is offline
post #3 of 4 Old 07-24-2010, 03:48 PM
TRX700XXX's Avatar
Don't engines run better when there hot tho??
TRX700XXX is offline
post #4 of 4 Old 07-24-2010, 04:09 PM
USMC0861's Avatar
your engine will still run in the optimal heat range with this stuff....it just helps keep it there longer...everything in moderation....If an engine overheats bad you can really mess it up....they were built from the factory to run in a certian heat range...when we start tweaking to get more Hp and push it to its limits (racing/enviromental) the temps rise....cheap insurance
USMC0861 is offline
