Guinea Pig Review #1 Wiigstyle Racing Rear Shocks. - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 08-09-2010, 06:28 PM Thread Starter
Tried them this Sunday whilst racing a 3 hour enduro.
I waited for results as this is a confirmation on a product I try.
And well ! Remington Steel is right, Josh really knows his stuff and built a really good product. I would use great but that would be comparing them to PEP PB1's.
I did the scientific evaluation and seemed stiff at first. (Pushing on the grab bar ). Put the compression adjusters at 1 turn in. My mistake.
This is a primary evaluation as my front Elka's turned into po-go sticks 20mins into the race.
The Wiigstyle modded rear stockers performed really well and better than expected for the price. There were predictiable and I managed to make them bottom out a couple of times but inspired confidence and I got a 5th the hard way. The track was 5 miles long and with no rest time except a 400 yd strip in one of the woods sections. Those who race will know what I mean. The rest of you ,this a place where you can relax at race pace .
I am impressed and wish Josh wasn't 3000 miles away , so I could send my front Elka's in.
All in all , I am comparing the "Lazy" stock shocks to the Wiigstyle modified stock rears and I really do like them and for the money I ain't complaining.
I'll sort out the front Elka's and post after my next race on September 4th.
Thanks Remington Steel for suggesting Josh and Thanks Josh, You did a good job.
P.S. Don't lie about your rider weight , I do for most shock builders for some great shocks but this time . I did not lie and gave Josh my true weight and it has been the closest yet.
The Brit.
post #2 of 10 Old 08-09-2010, 06:43 PM
Baxter,
What kind of service did you have done to them? Is it a dual rate conversion or a revalve and respring? Any pictures to post?
Rancher2005 is offline
post #3 of 10 Old 08-09-2010, 06:48 PM Thread Starter
Originally Posted by Rancher2005 View Post
Baxter,
I had the full works , revalve , dual rate springs and the compression adjuster added.
I have pics and will show them fitted , gimme 5 mins.
post #4 of 10 Old 08-09-2010, 06:55 PM Thread Starter
Here ya go !
post #5 of 10 Old 08-09-2010, 09:15 PM
TRX700XXX's Avatar
Nice review, did you ever feel that you needed rebound adjustment too? And what was wrong with the Elkas?
TRX700XXX is offline
post #6 of 10 Old 08-09-2010, 09:24 PM
I think his elka's are just in need of service is all! He ride's pretty darn hard from what i gather!
post #7 of 10 Old 08-09-2010, 10:05 PM
Some people might not understand the stress that I went thru making sure everything was spot on for Baxter. Considering he is 3000 miles away and all I was double checking everything and triple checking to make sure everything was race ready.
I do have my own modified shocks that were the first and have since been used and abused. But, Baxter was the first customer and I thank him for that.
If anyone needs there rear shocks set-up I offer a revalve, respring, rebuild for the rears for all weights and riding styles. Please pm me here for any questions or call me at 712-621-5191.
Thank you.
Josh
WiigStyle Racing Suspension
wiigstyle is offline
post #8 of 10 Old 08-10-2010, 02:24 AM
glad to hear you are happy with them! i knew josh would take care of you. "hey josh wheres my kickback???"lol
post #9 of 10 Old 08-10-2010, 02:16 PM
Talk to me this winter when there is some downtime and I will get you taken care of.
Josh
post #10 of 10 Old 08-11-2010, 07:02 PM Thread Starter
The valving was spot on I didn't miss having a rebound adjuster.
Took the Elka's off tonite and I think I have blown the bladder or piston seals . They are stage 1 fronts and both shocks have air or nitrogen in the main chamber .
First 11/2" shaft movement is with no resistance the it hit the oil and goes to normal.
