Question on the fuel consumption for the 700xx? - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 03-21-2011, 03:21 PM Thread Starter
sad Question on the fuel consumption for the 700xx?
I am used to my TRX680 Honda Rincon Quad bike and I have recently won the first leg of one of our local trail riding competitions in South Africa......I have bought the TRX 700xx two weeks ago and need to know how far I can ride without refueling, the trail is a 100km long(5 laps of 20 km)......will I make it with one tank of fuel?
Lipstick Biking is offline
post #2 of 13 Old 03-21-2011, 03:33 PM
I would think a stock bike could make it. The big three uses quite bit more fuel.
post #3 of 13 Old 03-21-2011, 03:38 PM Thread Starter
Big Three? Explain?
post #4 of 13 Old 03-21-2011, 04:39 PM
traitor08's Avatar
Big 3 is , air filter-pipe-programmer. The bike is lean from the factory and gets good mileage. It needs more fuel with better breathing and it goes down from there. There are auxiliary tanks for these if you ned one. I think on jokersracing.com. supposed to be the same one matlock uses for the baja.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #5 of 13 Old 03-21-2011, 05:28 PM
TRX700XXX's Avatar
100km is about 60 miles so with stock motor i think you can make it using reserve. With big 3 and being on it the whole time would be really cutting it close. Either way I'd put a splash in after 3 laps.
TRX700XXX is offline
post #6 of 13 Old 03-21-2011, 07:24 PM
Stock setup , No.
The stock tank(stock motor) goes for 2 hrs, then it quits. Put it on reserve ,it will get you to the pits. This is what I have learned.
100km is about 62 miles . You may need to refuel.
post #7 of 13 Old 03-22-2011, 12:42 AM
The best I have done so far is ago 70km I i needed reserve and that isn't hard riding
z400 is offline
post #8 of 13 Old 03-22-2011, 01:34 AM
AusTrx700xx's Avatar
when i was pre running here in aus with a 15t front sprocket, slip on, and modified filter lid i was getting about 180km using reserve, but since i went full system, fuel controller, prodesign intake kit, and no filter lid it dropped to about 110km, but gets there quicker
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #9 of 13 Old 03-22-2011, 04:19 PM
TargetDrone's Avatar
I was running a stock bike with a big gear down and 25" tires last year, and we did 100k trails. And we like to play in the mud!
Black 700XX "Blitzkrieg"
12t Sprocket
Pro Armor Full Chassis Skid
ITP T-9 Pro Wheels
22x11x10 Swamp Lites
Big Ugly Snorkel Out Back
DIY A-Arm Guards
DIY Removable Back Rack
DIY 1750lbs Winch + Push Bar
TargetDrone is offline
post #10 of 13 Old 03-22-2011, 09:19 PM
I agree... fill up around halfway, if you have a chance...
