Teixeira Tech CXC Uppers Review, Installation and Pictures. - Club700XX - Honda TRX700XX Forum
post #1 of 31 Old 03-28-2011, 10:47 PM Thread Starter
92K1500's Avatar
Cant decide if you want to drop the coin on the CXC upper arms?
Maybe this will help you.
Review:
At first glance they look a lot nicer than the stock arms. Feel nice and sturdy.
Installation was a breeze. Setup was a little time consuming but not terrible.
First ride impressions: Turns 1000.5% better, feels fine.
Was barely on the throttle (didn't have grease in the bearings yet so I wasn't being rough with it) and it will turn like a solid axle now.
Lightly dragging the front brakes and shifting my weight I could almost pivot around the front inside tire doing donuts on grass. Something I could never do before. It would always try to pop a wheelie.
First race with them:
Not having much seat time on them I was kind of leary going into my first race (Cross Country) with the arms. But after about half a lap I soon found out I LOVE THEM!!!!
They make the front end feel a little light but it turns sooooo much better you would never think it was possible from a XX.
I made some turns that solid axles couldn't even make. They seem to help the tires grab and pull the front end around instead of pushing through the turn.
After the first lap it was like riding around on a couch through the woods and it turns like it should have from the factory. And jumping wise it didn't change a thing.
I can't comment on the high speed/desert style riding though. I only have experience with them in the tight trails of XC.
Installation:
Couldn't be easier to install.
Put the front end up on a jack stand to let both front tires hang freely and remove both front tires.
Unbolt the brake line clamps from the upper arms and pull the brake line out of the hook, but leave it attached to the caliper.
I found it easier to remove the bolts at the frame first, so remove both of them and set them aside as you will need them later.
Then get the cotter pin out in whatever fashion you wish. (I just broke it at the eyelet part and pulled them out in two pieces) Then remove the nut and toss it aside.
Next get the arm moved to where you can pull up on it and take a hammer to hit the sides of the spindle around the ball joint. Doesn't take much effort so don't go King Kong on it. May have to move back and forth from side to side once or twice. My left side came out with two hits, the right took about 5.
If you want to keep the stock arms for spares, put the nuts back on the ball joints and put them in a place where you wont lose them. If you don't want them put them on here or eBay or something.
Get out your new arms, put your ball joints in them with the small nut and toothed washer on the ball joint side, and the other toothed washer and large lock nut on the frame side.
Make sure you have the correct side (I put one on upside down first) and slip the ball joint into the spindle. Then put the washer (if there is one, I don't remember) and lock nut on, and tighten it down to seat the ball joint and make sure it wont wobble around.
Next put the other ends in their holders and install the bolts you set aside from earlier.
For the brake lines you can either use aftermarket holders (Teixeira Tech makes some as well as many others) or do as I did and just use zip ties.
Adjusting:
This can get time consuming but once you get it done it's well worth it.
Ed told me for XC racing you want -2* camber with a rider on it. I found this to be a big PITA so I went with what another member on here said and set them to -1* unloaded (on the jack stand) and they seemed to work fine for me.
I used one of these
And a flat piece of metal to go across the rim to measure my camber.
Then I set the caster on the second tooth from the front.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #2 of 31 Old 03-28-2011, 10:59 PM Thread Starter
92K1500's Avatar
Pictures:
This is how it looks installed. You can see I just used my stock rubbers from the stock clamps and ran 2 zip ties around them to hold the brake lines to the arms.
This is how it looks after hitting a tree.
But this is how another members looks after the same thing.
So either I got lucky or the TT's are much stronger.
Random cell phone pic while working on them.
Overall I was happy with them. I just wish TT made stock replacement lowers too.
Hope this helps you.
2008 Honda TRX700XX
92K1500 is offline
post #3 of 31 Old 03-29-2011, 04:06 PM
TRX700XXX's Avatar
Great review! looks like I won't be able to really test my a arms until the trip to WV in April.
TRX700XXX is offline
post #4 of 31 Old 03-29-2011, 07:35 PM
ranger19jn's Avatar
Um I'd say the teixeira arms are much stronger than stock
Where is the vid man it should have been up by now
08 trx700xx lot's O mod's
08 ktm 525xc modded
08 yamaha 450 lightly modded
05 grizzly 660SE (sold)
11 rzr s (sold) and missed
sponsors:
Manford Auto Supply (NAPA)
Teixeira Tech:
L8aton Racing:
Fox Racing:
powermadd:
ranger19jn is offline
post #5 of 31 Old 03-29-2011, 07:52 PM Thread Starter
92K1500's Avatar
Helmet is still out in the garage.
I'll get around to it.
2008 Honda TRX700XX
92K1500 is offline
post #6 of 31 Old 03-30-2011, 09:13 AM
AusTrx700xx's Avatar
wish my a-arms help up that well when i hit the tree but as you can see from the pic they didnt, how fast were you going when you managed to hit the tree
nice review man, im keen on the teixeira tech arms but still decieding to go plus 2 or plus 1 1/4
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #7 of 31 Old 03-30-2011, 09:47 AM
Thanks for the review 92k1500! That XX that hit the tree looks brutal, hope the rider is ok.
post #8 of 31 Old 03-30-2011, 09:57 AM
i was in hosptial for about 2 days, severe soft tissue and muscle damage and a fractured pelvis, severe concusion smashed the chin guard off the helmet and put a split up the back of it, i landed on my right hip when i didnt see a whop in 5th pinned, still have a limp a yr on
post #9 of 31 Old 03-30-2011, 10:04 AM
Wow, that sucks. I just had a roofer who fell 25ft. off a roof and only broke his ankle. Dialed the patient in with morphine and it was allllll gooooood. haha
post #10 of 31 Old 03-30-2011, 10:07 AM
mmm morphine.... the only thing better than the morphine was the hot nurse who told me she was going to take my pants off!
