ride report - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 06-06-2011, 01:38 PM Thread Starter
ride report
so i finally got the bike late Saturday evening and immediately got onto fitting on the pro armor fat pegs and bumper. good solid equipment but a pita to fit on!
what can i say you guys got it spot on the bike pushes into corners and the rare shocks are mega harsh
so ive put it up for sale...
just kidding its all giggles!
tough to stay at 50% throttle for break in as i was having so much fun and always wanting for more power, does it really do 86mph? cause ill be seeing that side often...
it was such a pleasure knowing that all the big rocks were too small to hamper the trx's progress (ground clearance)
over the week ill put in the ds shocks and swap the front springs to the rear.
if that works ill be looking to Ed at texiera and kyle at l8ton to put me right (and left!)
if not then sadly it will have to go as elka and fox will put the price tag too high and ill have to stick to dirt bikes
overall a really great bike, fits the bill perfectly as a weekend toy but i bought it for high speed racing
tchui
tchui is offline
post #2 of 16 Old 06-07-2011, 04:41 PM
traitor08's Avatar
The xx has a pretty good top end on it. From what I read, the limiter hits at 87. A factory bike cannot hit the limiter. I have had my stock xx up to 80 and had to shut down because of corner. Some say a good running bike with the big 3 can do 85. You just get ther a lot faster. One gy on here says he hit limiter on dyno with a 15t(stock 14) front sprocket. That should put him in mid 90s territory. Withe a smaller sprocket people still claim thehigh 70's because the motor has enough to push it to the limiter.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #3 of 16 Old 06-08-2011, 11:49 AM Thread Starter
putting in the ds shocks this week/end... helluva lot more cutting than i had anticipated, but am at the point of no return now...
i do hope i can sort the ride out.
it would be sad to let it go cause it really is good fun.
not planning on any engine / power mods and ive stalled it a few times as well so cant see myself changing away from stock gearing...
is 2 hrs a good break in period? can i open it up after that?
tchui is offline
post #4 of 16 Old 06-08-2011, 10:12 PM
swap the front sproket to a 13th and you probly wont stall as often.
post #5 of 16 Old 06-08-2011, 10:16 PM
traitor08's Avatar
I got a programmer and can take off idling, I am getting pipe, air filter and 13 t this week. Programmer changed a lot, and my head pipe doesn't get as red anymore.
MY RIDES
post #6 of 16 Old 06-09-2011, 05:52 AM Thread Starter
no more money left guys.... lol. stock power should be plenty for our rough terrain if i get the suspensions sorted and am up near the limiter 80% of the time ill look into power mods. im a firm believer that good suspensions and setup make you go your fastest, that and a few creature comforts like good sitting/standing ergos let you go faster for longer.
tchui is offline
post #7 of 16 Old 06-11-2011, 08:22 PM
With programmer and exhaust you may not want the 13t from what I hear.
post #8 of 16 Old 06-12-2011, 03:48 PM
TRX700XXX's Avatar
I have the big 3 and still use the 13T. It allows me to make really tight turns in 2nd gear and not need to go to 1st like the 14T does.
TRX700XXX is offline
post #9 of 16 Old 06-12-2011, 04:18 PM
post #10 of 16 Old 06-12-2011, 09:43 PM
Right and if racing, you dead start in 2nd too right?
