soo... I just bought a raptor.. i have questions - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 03-11-2010, 07:59 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
Found an 02 660 raptor on craigslist.. Needs motor work, but i got the whole thing for $250 .... if nothing else i can part it out and make a lil money. I have questions for someone who knows a lil something about raptors.... i think there is a member here (velosiraptor) or something like that?? anywho. hit me up if you have time to answer a couple questions.
ein is offline
post #2 of 11 Old 03-11-2010, 08:26 PM
kelodwro's Avatar
might be best to post your questions here now, that way people can think them over.
Also, if you are a Raptor guy, there are Raptor forums, (Wont have our great machine or members) but I am sure there are great guys that know their stuff there too!
Either option works great!
'08 700XX
Power:
EHS bullet box (Thanks Eric!)
Full HMF exhaust system
K&N air intake
Handling:
Flex bars 14* 31" Quad racer
Bling:
Honda Racing MX front bumper
IMS fuel tank
Red Silicon radiator hoses
Gripper seat
kelodwro is offline
post #3 of 11 Old 03-11-2010, 08:40 PM
Go to Bluetraxx.com. They can help you with all your questions. I got rid of my 01 2 years ago to get the XX and havent ever looked back. Spent lots of money on it and wish I had it all back. If you only have 250 in it, I would part it out and use the money on the XX. JMO.
12 RZR XP900
bduncan1231 is offline
post #4 of 11 Old 03-11-2010, 09:04 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
well, i know the piston and jug are trash, since i've got to replace those, should i go ahead and get a big bore kit?? The top of the head or rocker cover or whatever its called.. its got a hairline crack but i'm pretty sure i can weld that. i dunno, just looking for advice... any input would be appricated... and i know its a honda forum, but i just got a good deal and couldn't pass it up.
ein is offline
post #5 of 11 Old 03-11-2010, 09:31 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Try these sites.
http://www.raptorforum.com/forums/forumdisplay.php?f=57
http://www.moddedraptor.com/community/raptor-700/
Bo (VelociRaptor ) frequents both sites, both will be better for your raptor questions.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #6 of 11 Old 03-11-2010, 09:36 PM
09RappySE's Avatar
Quoted: 16 Post(s)
First thing you need to before you start a build is determine what type of ridding you want to do, what is your budget? the hairline crack you speak of is more than likely a casting line from the manufacture of the head, in any case Bo can take care of ya, including repairing the head if it is a crack and is repairable...Bo is top notch.
734 09 Raptor
post #7 of 11 Old 03-12-2010, 07:22 PM
If you are going to keep it then the best bang would be to take it to a 686 with a stage 2 cam. If you want some more then do the stroker crank that will take it to a 719. I did the Hot Rod crank with a CP piston, stage 3 hot cam, Kibble White valves FCRs and porting and put a lot of hours on it. Bo White aka Velociraptor can get you going. I would contact him. You can make some awesome power with any Raptor combo. Good Luck and open the wallet up
12 RZR XP900
post #8 of 11 Old 03-12-2010, 07:56 PM Thread Starter
ein
ein's Avatar
Quoted: 4 Post(s)
A stage two with double thunder cookies?? well.... i dont know about all that, im just trying to get a running 4wheeler for cheap... As far as performance goes, i'm just looking for stock... give or take. This weekend i'll tear down the bottom end/tranny and see if there is any damage... If there is i'll just part it out, if not i'll try and find a stock jug/piston and get it going, then go from there. I already have my dream machine (the 700xx) so this is just something to kindof keep me busy on the weekends kinda thing. Really, my question is, what do i need to do to it while its apart? What are some cheap mods that could give me better performance? While i'm replacing stuff on the top end, what are some reccomendations (keep in mind i'm going for cheap, not drag bike)..
ein is offline
post #9 of 11 Old 03-17-2010, 09:17 PM
Look on Bluetraxx there is a carb trick called the clear tube method that will help your throttle response and its basically free. It does take a little effort to set it up, but when I was running my stock carbs and did the CTM you could definitely tell a difference. Other than that, Run a good air filter (Lid off if you can), exhaust, correct jetting and maybe a cdi to raise the rev limiter will make you happy. They (660's) just dont compare to the 700R or the XX but you will still have fun. I still have a Ricky Stator cdi if you are interested.
12 RZR XP900
post #10 of 11 Old 03-17-2010, 09:19 PM
You can resleeve the jug and bump the compression up. 686's sure do run good for the money!
12 RZR XP900
