raptor lunch - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 21 Old 10-19-2010, 11:59 PM
08hondatrx700xx's Avatar
it dont matter weather u win by a mile or inches. if you lose you lose, if you win u win. theres always gonna be someone faster then the next person!!!
08hondatrx700xx is offline
post #12 of 21 Old 10-21-2010, 10:45 AM
RaVxX's Avatar
The 15T makes the XX a completely different type of beast, I had the 13T on, was way to slow IMO, put the 15T on wont go back, accually I'm going to put a 16T on the front with 20 Razrs 2s in the back, or else I may just drop 2 teeth in the back, not sure yet, even the take offs are better with the 15T.
RaVxX is offline
post #13 of 21 Old 10-21-2010, 11:48 AM
I would think a 15 tooth front sprocket on a big 3 no engine mod xx with 22" tires wouldnt be good.
Captamer71 is offline
post #14 of 21 Old 10-21-2010, 02:31 PM
RaVxX's Avatar
Captamer71, if you lived closer I would run you and you would find out, I would kill my friends XX (with the same mods) when he had the 13T on.
RaVxX is offline
post #15 of 21 Old 10-22-2010, 02:02 PM
simple fix to this make the race shorter( oh i beat you now were done) remides me of a race i saw between a viper and a z06 corvette. viper ate the corvette alive for almost an entire mile and the vet passed it in the end with just more top end. i would rather be quick than fast. and yes there is a differenve.lol
post #16 of 21 Old 10-24-2010, 10:58 AM
sicksnake's Avatar
As a bright man once said.... "WINNING IS WINNING"
sicksnake is offline
post #17 of 21 Old 10-24-2010, 11:55 AM
Tim700xx92's Avatar
if you win by an inch or win by a mile...winnings winning
Tim700xx92 is offline
post #18 of 21 Old 10-28-2010, 05:16 PM
we race from the bottom of the hill to the top of the hill. which is about 400 feet and at the dunes i see some guys once they pull in front they just stop LOL after like 100 feet but those are the guys with the supped up utility quads that kawasucki praire thing its fast till it tops out at 100-150 feet then if he doesnt stop he gets passed. but why race for over 3-500 feet??? i dont see a 15 tooth being able to beat a 14th tooth till you have went past that distance?
But I will keep a open mind. I guess if you goto a 15th tooth you launch in 1st?
btw i am running a 14th tooth.
post #19 of 21 Old 04-14-2012, 04:05 AM
Just race that high geared raptor on some rocky terrain is it still a All Terrain Vehicle or a Limited Terrain Vehicle .
griggsyxx1 is offline
post #20 of 21 Old 04-14-2012, 07:59 AM
I am in uk so road legal..this gives me the advantage that i have had thousands of traffic light take offs so have it perfected..
When i had my 660 raptor i had 12,13,14 front sprockets..
A friend had a stock one too.
Each sprocket change i raced him on road and the surprising thing was that 0-60 was still the same regardless of front sprocket.
A 12 may allow you to shoot off rapidly from standstill, but you loose so much acceleration within the powerband changing gear,whilst the 14 geared is spending more time accelerating in a gear and less time shifting, getting more power down on the road. (i hope you understand what im trying to suggest)
I,ve run 15 front with 24" rears on road and it is far better than any other combination,giving a great 1st gear for taking off and enabling cruising at 60 all day long without revving the guts out of the engine.
I tried a 13t on road and it was not good.
the 15/24" works off road too until the very technical stuff at slow speed, leading to lots of clutch work.
I,m now running 15t and 22" rears as a compromise for on and off road.
I found that a 2" reduction on the rears is very similar to 1 tooth reduction on front.
rappey is offline
