Paddle tires in snow - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 12-13-2013, 10:56 PM Thread Starter
Tony_Carr's Avatar
Does it work? How good or bad is it? I am suppose to get like 6 inches of snow and I'm lookin to have some fun on the xx. Who has done this before?
Flint Michigan Vehicle City!
Tony_Carr is offline
post #2 of 10 Old 12-13-2013, 11:51 PM
XxX700XxX's Avatar
Doesn't work all that good..not for me anyway
2009 700xx
1989 yamaha banshee
not stock
80hp
XxX700XxX is offline
post #3 of 10 Old 12-14-2013, 09:15 AM
quadmonkey700xx's Avatar
it works a little in a real wet snow. but i prefer knobbies with ice screws.
quadmonkey700xx is offline
post #4 of 10 Old 12-14-2013, 11:20 AM
Quoted: 252 Post(s)
Aren't most paddles 2 ply? Including the Maxxis 4-snow Tires? I'd stick with a 6 ply tire like the Bear claws.
M_Quick is online now
post #5 of 10 Old 12-14-2013, 05:37 PM
Yeah I think most are. For my ice screw tires I use a tire like razr's that have big beefy lugs. Over the years I have had several different sets and the type of tread doesn't seem to make a difference other than how well they hold the screws. I usually use a half wore out set of tires that I have replaced but still holds air. Then I estimate how thick the tire still is in the lugs, and buy hex head sheet metal screws from the hardware store that are a little shorter. I usually get about two hundred in each rear tire and One hundred in each front. I then use a shot of green slime because there is always some that went thru. Even with that I will usually have some leaks so I may have to add air anytime I ride with them.
post #6 of 10 Old 12-14-2013, 09:26 PM
X2 on tires with ice studs they work awesome and when on ice they hook up better than on pavement I couldn't believe how well hey work just done ride pavement with studs they wear out real fast I studded my stock tires they are a bit soft but they worked for me the more studs u put in they better they seam to stay in the tire I put two in every other lug and one in the others
z400 is offline
post #7 of 10 Old 12-14-2013, 10:40 PM Thread Starter
Tony_Carr's Avatar
I was just going to do it for fun it was light fluffy snow so I was just out drifting and doing donuts. I still have the stock tires and am planning on getting new ones so I'll just stud the oem ones
post #8 of 10 Old 12-15-2013, 12:11 AM
Jmm24's Avatar
I put paddles on a honda recon 1 time in the snow, think they were itp sandstars and they pulled great in the snow. Was about 8-10 inches of powder but a big difference from the stock recon tires anyway
Jmm24 is offline
post #9 of 10 Old 12-15-2013, 11:32 AM Thread Starter
Tony_Carr's Avatar
That's what I have I was going to out them in but the stock tire did just fine
post #10 of 10 Old 12-15-2013, 08:05 PM
Jmm24's Avatar
Yea probably better off with stock overall because sand tires are the worst for hard packed riding
Jmm24 is offline
