cylinder studs - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 02-22-2014, 06:52 PM Thread Starter
nacho's Avatar
Quoted: 11 Post(s)
cylinder studs
I need a second opinion. I did a top end job on my 85 ATC250R a while back now. I was not satisfied with the way the head seated on the cylinder. I did buy a spare cylinder and head, and had the cylinder bored for the new piston. Anyway, I torqued the head according to the manual. I started it up and it had a slight coolant leak. I did get it to stop leaking, but I went quite a bit beyond the torque specs. Neither the cylinder nor head are warped. And yes, I did use a new head gasket. My question is, is it common for the cylinder studs to stretch? It recently developed another minor leak, so I ordered new studs and nuts, and a top end gasket set. Is there anything else I haven't considered?
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #2 of 6 Old 02-22-2014, 06:58 PM
Tony_Carr's Avatar
I know that they can stretch on a head on a car do it's possible. The new studs should fix it
Flint Michigan Vehicle City!
Tony_Carr is offline
post #3 of 6 Old 02-23-2014, 09:19 AM
09RappySE's Avatar
Quoted: 16 Post(s)
How do you know your head or cylinder is not warped? did you have them resurfaced when the cylinder was bored? Can head studs stretch...yes, and depending on how much over you went on the torque specs...they most likely are now. If you did not have the head and cylinder resurfaced this teardown, my guess would be that one or both is warped, assuming the head gasket was good when installed...it does not take much.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #4 of 6 Old 02-23-2014, 11:02 AM Thread Starter
nacho's Avatar
Quoted: 11 Post(s)
He did check them, but they were not resurfaced. I tore it down yesterday and checked them myself and had the shop check as well. Neither are warped. I have replaced the studs and replacing the head gasket. Whenever a person buys a new gasket, it is assumed that they are good. That could have been part of the problem. This time, I am using an OEM.
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #5 of 6 Old 03-01-2014, 10:55 PM Thread Starter
nacho's Avatar
Quoted: 11 Post(s)
I finished putting everything back together and all is well. No leaks and torqued the head to spec. I compared the old studs with the new ones, and I could tell no difference. They did not appear to be stretched. Since everything else checked out, I am suspecting it was a bad head gasket.
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #6 of 6 Old 03-02-2014, 03:02 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Glad you got it worked out.
734 09 Raptor
