Warranty question - Club700XX - Honda TRX700XX Forum
post #1 of 20 Old 05-11-2014, 08:32 PM Thread Starter
XxX700XxX's Avatar
Warranty question
I'm gonna be taking my 700 back to the dealership since its still under warranty I'm having a problem with the trans today while riding it was cluncking in 2nd when I was doing 2nd gear holeshots and it shifted from 4th to 5th by its self and it was popping out of gear...my question is will my exhaust void the warranty if so I'll put her back to stock when I take it in
Sent from my XT907 using Tapatalk
2009 700xx
1989 yamaha banshee
not stock
80hp
XxX700XxX is offline
post #2 of 20 Old 05-11-2014, 08:40 PM
Quoted: 255 Post(s)
IDK for sure, but I'd replace it to stock. I couldn't even get my dealer to replace the fuel shut off lever. And come to find out later, they had to remove it to adjust the valves when I took it in for break in service. I thought I should do this in case I had warranty issues down the road. I hope you have better luck with your dealer.
post #3 of 20 Old 05-11-2014, 08:47 PM Thread Starter
XxX700XxX's Avatar
Hmm that doesn't help my confidence lol
2009 700xx
1989 yamaha banshee
not stock
80hp
post #4 of 20 Old 05-11-2014, 08:56 PM
Quoted: 255 Post(s)
Yea it's bs when the dealer wouldn't give me a $12.00 part. He said for one he never heard of the problem, I gave him a link to a thread here where several member's reported theres missing. I wish I knew at the time removing & replacing it was part of the valve adjusting process. I did tell him for reasons like that I would never visit them again, and so far I have stuck to my word. And don't let me get you down, other members here have had great success getting things cover'd under warranty. I hope your dealership is a good one and takes care of you.
post #5 of 20 Old 05-11-2014, 08:59 PM Thread Starter
XxX700XxX's Avatar
Well hopefully they fix it I'm guessing a fork bent
2009 700xx
1989 yamaha banshee
not stock
80hp
post #6 of 20 Old 05-11-2014, 10:14 PM Thread Starter
XxX700XxX's Avatar
Any clue what the problem could be
2009 700xx
1989 yamaha banshee
not stock
80hp
post #7 of 20 Old 05-12-2014, 06:00 AM
Quoted: 255 Post(s)
Sounds to me like same thing your thinking, bent shift fork. Baxter would know more, I think he's had tranny problems and had his apart a dozen or so times.
post #8 of 20 Old 05-12-2014, 04:58 PM Thread Starter
XxX700XxX's Avatar
I just hope they know what there doing at the dealership and don't just putt it around the parking lot and call it good
2009 700xx
1989 yamaha banshee
not stock
80hp
post #9 of 20 Old 05-12-2014, 09:07 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Good luck....I would not tell them you have been doing any racing/holeshots or anything, I am sure it is a bent/worn fork and or the dogs on the gears....be prepared to get the this is not covered due to abuse speech.
Hopefully you can get them to cover it, but I doubt it.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #10 of 20 Old 05-13-2014, 01:42 AM Thread Starter
XxX700XxX's Avatar
Over the phone they said they'll replace any worn out items in trans if its causing a problem idk tho
2009 700xx
1989 yamaha banshee
not stock
80hp
