fuel shut off valve - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 11-14-2009, 12:42 AM Thread Starter
gavineli's Avatar
fuel shut off valve
Anybody else have problems with it comeing off mine has came off once and found it loose a second time.
amy ideas about keeping it tight besides locktight?
gavineli is offline
post #2 of 12 Old 11-14-2009, 05:59 AM
I took mine off and put it in the little canister under the seat.
post #3 of 12 Old 11-16-2009, 03:55 PM
Mine fell off a few months ago. I keep a pair of long nose pliers under my seat just in case I ever need to turn it to reserve.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #4 of 12 Old 11-16-2009, 04:16 PM Thread Starter
gavineli's Avatar
Mine fell off and by some freak chance it was in the feild leading to the trail head along with the bolt that holds it on i want to figure out a way to keep it from falling off agian
gavineli is offline
post #5 of 12 Old 11-16-2009, 05:19 PM
IMO it's not worth the trouble. But you could put Liquid Nails or JB Weld on the threads and it should NEVER come off again.
post #6 of 12 Old 11-16-2009, 06:58 PM
Blue Loctite would be better than J B weld and Liquid nails. It would take a lot less to remove when needed. Never had a problem with this.
post #7 of 12 Old 11-18-2009, 01:27 AM
BiFfMaN's Avatar
Purple Loctite (222 or 221) weakest, made for small hardware.
Blue Loctite (242), Medium strength, we use on 1/4 or larger bolts.
Red Loctite (262 or 272) High strength, if you never want to remove the screw ever again. actually yah i will come out..just neet to heat it too 500+F to get it off.
Or Green loctite (620) a retaining loctite used to help fit loose fit bearings, would work great holding on the knob on without a screw. and with a little heat (hotter then the motor) you can still remove without destroying the knob.
been working on Aircraft for about 17 years now...so loctite is a friend to me. Especially on a pusher prop aircraft...all fasteners seem to find its way to the prop.
BiFfMaN is offline
post #8 of 12 Old 11-18-2009, 01:30 AM Thread Starter
gavineli's Avatar
Thanks for the info that realy helps i think the purple should be just fine
gavineli is offline
post #9 of 12 Old 11-18-2009, 02:08 AM
BiFfMaN's Avatar
Oh mine fell off first day riding....dealer got me a new one. Installed it using blue loctite, been on since.
Blue is easy to find also.
BiFfMaN is offline
post #10 of 12 Old 11-18-2009, 03:16 AM Thread Starter
gavineli's Avatar
So blue wont hold it to tight if for some reson i need to get it off ?
Last edited by gavineli; 11-18-2009 at 03:18 AM. Reason: tired and repeeted myself
gavineli is offline
