I need some help on my Suzuki - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 02-09-2015, 11:10 PM Thread Starter
Scallywag's Avatar
Ok so i went over to the suzuki forum to get some help, and they were not very helpful. I bought an HID conversion to put on my wifes KFX400. The lights do not currently work on the quad. When you move the high/lo switch it doesnt feel like it does anything. So I thought I would just pull the power directly from the ignition switch.
Here is a link to the wiring diagram I planned on using the green wire to power the hid.
http://www.suzukicentral.com/forums/...g-page0001.jpg
So if Im pulling power from the ignition can I just get my ground from the frame?
Scallywag is offline
post #2 of 5 Old 02-10-2015, 06:52 AM
Snoshoe's Avatar
basic starts, power, connections, relays, and switches. grab a multimeter and follow the diagram from the battery to the lights. frame should be ground just check where the neg cable goes from the battery.
side note I did have a similar problem with my 96 miata high beams didnt work unless i used the "flash" mode. had to tear apart the switch and clean up the contacts with some fine sand paper. works great now to get them aimed right oiy
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #3 of 5 Old 02-10-2015, 09:29 AM Thread Starter
Scallywag's Avatar
Im actually fine with not having a high/lo switch. I just want to know 2 things.
1 Can I use the green line coming from the key switch as my power (coming out of 17 on the diagram)
2 do I have to connect into a ground line, or can I connect my ground to the chassis
I am not that interested in chasing wires through the quad and figure out why the original system isnt working. The ignition is close to the light. I can easily pull a wire from the ignition if that will work. The negative from the battery appears to just go to the frame (on the schematic). Im pretty sure this will work, I would just like someone with more experience look at it and see what they think
post #4 of 5 Old 02-10-2015, 10:35 AM
Quoted: 62 Post(s)
I wouldn't say that I have more experience, but I have run stuff off the ignition wires and grounded to frame and it's worked just fine. I've used this chart to get an idea of how much the wire can handle (doesn't mean the fuse isn't lower).
http://www.offroaders.com/tech/12-vo...gauge-amps.htm
mumbauer is offline
post #5 of 5 Old 02-10-2015, 10:46 AM Thread Starter
Scallywag's Avatar
Thanks for the chart mum, however the HIDs actually use less wattage then the regular lights. The green wire is for the lights anyway it just runs over to the high/lo switch on the handlebars first.
