need advice - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 01-21-2010, 10:44 PM Thread Starter
need advice
Looking to buy 2 quads, considering TRX700 and TRX 250.
How are the 2008 TRX700 and 250, one for me other for my kids.
I am going to look at two used quads both are from year 2000 a 300 ex and a 400 ex, they are not running been sitting idle for 5 years they are supposedly in good shape. I have no clue about quads, but have been reading everything you have said about the TRX 700 and I am excited.
With the deals on TRX's I am chomping at the bit to buy the new ones, need advice
PS no mechanic here, I just want a solid fun bike.
Birdster63 is offline
post #2 of 12 Old 01-21-2010, 10:51 PM
phucknutz's Avatar
bikes are cheap now, if looking at the older ones I would say a 2000 300 is worth about $800 to $1000 at max and the 400 $1000 to $1400 max. They will need the carbs cleaned and oil changed before you do any riding and you will more than likely need a new battery for both, they will shock you when you see the price of a new battery. I would get the deals on the new 700 and 250. you can buy a new 700 for about $4200 and a 250 $2300 cant go wrong
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #3 of 12 Old 01-21-2010, 10:59 PM
And don't forget the Maintenance you'll need to do on them since they've been sitting there for 5 years, depending where they've been sitting, you might need to tare them apart and clean/grease and lube them and even might have to replace some parts due to rust/dirt
If you can afford it, I would purchase new and the 700-250 are both good bike. How old is your son, he might out grow the 250 in a year or so depending on his age.
Notice that you're from NJ, look in PA, they usually have better deals there.
post #4 of 12 Old 01-21-2010, 11:01 PM Thread Starter
thats exactly what I thought, thank you for your quick response, cheapest I can get in New Jersey is @4550 and 2550 for without taxes, have to have brother in PA register in his name.
post #5 of 12 Old 01-21-2010, 11:08 PM
those are pretty good prices but I would still ck in PA and let them know about the quotes you got in NJ.
post #6 of 12 Old 01-21-2010, 11:08 PM
Which part of NJ are u
post #7 of 12 Old 01-21-2010, 11:12 PM Thread Starter
Williamstown
post #8 of 12 Old 01-21-2010, 11:12 PM Thread Starter
Crossroads in Upper Darby does not have TRX 250 in stock
post #9 of 12 Old 01-22-2010, 12:07 PM
Something to consider is that the 250ex has a sport clutch and while that may be easier for a kid to learn and is a good solid machine. The 300ex may be a better choice for the following reason. At some point a kid will outgrow their starter quad and starting with a machine that's closer in operation to a machine that they'd want AFTER their starter quad will make for an easier transition to a larger quad. Learn to use a full clutch right from the start. IMO
post #10 of 12 Old 01-22-2010, 12:36 PM
Thorsky's Avatar
Bird, I just bought a 700xx and 2 250ex's for the kiddos. Couldn't be hapier with the purchase. Right now all I can do is super tight technical trails on my own property and the 250's are perfect for that. The 700 is just too big and fast. I find I'm on a 250 about half the time, much to the chagrin of my kids.
2008 TRX700xx
- EHS Airbox - UNI Filter - Barker Exhaust
- EHS EFI Controller
- RAZRs all around
2008 TRX250EX, Jet Kit, UNI Filter, Airbox mod
2008 TRX250EX, stock for now
2009 KingQuad 750!
Thorsky is offline
