atv locksmith help - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-13-2016, 02:12 AM Thread Starter
atv locksmith help
when I put the key into the ignition and turn it, the light comes on but the engine does not buzz.. this could be a wiring issue or an electrical one.. could be a problem with the lock itself.. should I call a locksmith?
ibadjas is offline
post #2 of 6 Old 04-13-2016, 09:44 AM
Quoted: 62 Post(s)
Use a test light or volt meter to see where electricity is going. Fairly easy to do and will help wasting money where it's not needed (could just be a fuse).
mumbauer is offline
post #3 of 6 Old 04-13-2016, 01:34 PM
Quoted: 255 Post(s)
Waste of money for sure, if you called a locksmith out. The key fits into the ignition, and turns, so nothing a locksmith could do. Unless is multi talented? Might be different if you needed a key cut.
post #4 of 6 Old 04-13-2016, 01:36 PM
Quoted: 255 Post(s)
Yeah, check volts at battery would be my 1st step. Then see if it makes it to the starter, past the relay.
post #5 of 6 Old 04-18-2016, 12:54 AM
locksmiths these days are usually trained to handle these things
soutfransic is offline
post #6 of 6 Old 04-19-2016, 03:26 PM
Quoted: 255 Post(s)
are you serious?
Originally Posted by adamcarrick View Post
The auto door lock on ignition works only for the driver side door.. I am usually careful enough to check all the locks.. but this is a safety issue.. then call yo momma,they make my work very easy and enjoyable.
Tempted to delete this ^^^^^^crap as spam...Yeah i think I will.
