computer help - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 02-11-2010, 03:27 PM Thread Starter
computer help
if any one can help it would be great!
heres the problem i cant access club700xx at home first i thought it was the computer blocking the site but then i realized i couldnt log in with my lap top either on the same internet and again with my iphone when on wifi. so all i can figure is its my internet not allowing me on but dont have a clue how to fix it... and i have lots of pics and vids i want to put up
post #2 of 18 Old 02-11-2010, 03:32 PM
Are you able to access other web sites and sounds like you are running a wireless router check your routers settings which I doubt that they have change but you never know, also check with your provider if you are having this problem only at home, what is the error that you are receiving?
post #3 of 18 Old 02-11-2010, 04:02 PM
So.... How did you make this post if you cannot get on?
post #4 of 18 Old 02-11-2010, 04:13 PM Thread Starter
yeah i can go to anyother website just not this one it keeps coming up with unable to connect to site. and shhh im at work but all my pics and vids are on my home computer.
post #5 of 18 Old 02-11-2010, 05:14 PM
Try to get on through Google translator, Be sure to double check the address
post #6 of 18 Old 02-11-2010, 06:18 PM
I bet its the "ID ten T" error...
post #7 of 18 Old 02-11-2010, 06:21 PM Thread Starter
would that cause it not to load on all my computers and phones?
post #8 of 18 Old 02-11-2010, 06:23 PM
It quite possibly maybe might kind of could.
By the way.. ID ten T = ID10T also
post #9 of 18 Old 02-11-2010, 06:25 PM
I might call your ISP and see if any changes to your account have been made. Then I'd talk to the Admin about checking your IP range here on the site, he can block certain IPs cause of spamming. You could have accidently been encompassed in that. If you can get to every other site though and you can get to this site from any location outside of your home, i'd bet it is one of those.
post #10 of 18 Old 02-11-2010, 06:33 PM
Yeah, it could be posible that your link is broken. Try to get here from google. If that dont work then you should try to ping this site. To do that go to the start menu--->run--->type cmd---> type ping www.club700xx.com and hit enter. If your packet loss is 100% then your being blocked out by something. Maybe your router or firewall. If its none of those then its posible that the admin could be playing a sick joke on you by blocking your IP address. Other than that im not really sure why you cant get on, but good luck none the less.
DIEB4ME is offline
