Range? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 02-26-2010, 12:25 PM Thread Starter
USMC0861's Avatar
Range?
So I searched the threads and didn't really find alot on this. (and I do realize that this is subject to riding style) On average how far are the trail riders here comfortable going on a tank of fuel (regular or IMS tank) between fuel stops? I'm looking to take some longer trail rides this summer to mix it up...(trying to go north to south across UP MI and back)...but the last thing I want to do is run out of gas 10-30 miles away from anything. I am aware of the IMS tanks and PRM's prerunning rear tank. But what I am looking for is miles per tank/gallon estimates. Any help would be much appreciated....Dan
USMC0861 is offline
post #2 of 15 Old 02-26-2010, 12:48 PM
When I rode in Jackman Maine, did over 70 miles without a fill up and going an average of 45 mph. On our regular weekend trips we usually do about 45 miles + and when I fill up, it usually takes less then 2 gallons. Now when I did that 70 miles, had an extra 1.5 gas tank attach to my rear grab bar and used it on the way back.
post #3 of 15 Old 02-26-2010, 12:59 PM
The last long run I had was at 68 miles on wide open fire roads and we were pegged in 4th and 5th for good portions of the roads. Got back to my truck and checked my tank at the end and was about 1/2 left.
post #4 of 15 Old 02-26-2010, 01:22 PM
phucknutz's Avatar
mine on the stock tank ran out (dry) on a 58 mile race. It dosn't help you much but you asked
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #5 of 15 Old 02-26-2010, 02:40 PM
I think we rode about 81 miles last summer in Hatfield McCoy trails, and mine took just about 2 gallons. I was running about 3rd gear most of the time in the middle RPMs.
post #6 of 15 Old 02-26-2010, 03:34 PM
ive done a few 50-65mi races and have been fine on all of them.
post #7 of 15 Old 02-27-2010, 07:21 AM
warlock28's Avatar
The wife and I have a loop that we do that is about 31 miles. It takes about a gallon of fuel to cover the distance. About half is sandwash (flatout 4th-5th) the other half rocky desert hills (technical 2nd-3rd).
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #8 of 15 Old 02-27-2010, 02:15 PM
I did almost 40 miles one way at Hatfield McCoy, hit the gas station in Man and only needed 1.25 gallons to top it back off before heading back to Gilbert.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #9 of 15 Old 02-28-2010, 11:02 AM
skier207's Avatar
Riding a mix of dirt roads and trails I get 100-110 miles (gps) before I hit reserve. Didn't change much when i added a pipe and fuel controller.
skier207 is offline
post #10 of 15 Old 05-12-2019, 08:08 PM
Deephaven's Avatar
Quoted: 21 Post(s)
So in case others of you are reading this with expectations, be careful as it varies a ton on your riding conditions. I was super confident that being my first ever ride on an atv that I would exceed what most on here get. Much to my chagrin at 36mi I ran out of gas on the first day I rode the beast. Day 2 at 38mi I had a little more left, but not enough to make 45mi even.
Deephaven is offline
