which is a wider offset? - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 03-01-2010, 09:01 PM Thread Starter
which front rim offset would go with a rear offset of 3+5.would you use a 4+1 offset or a 3+2 offset?Dont want somthing to narrow or looks really wide or weird looking
tkbigbore is offline
post #2 of 2 Old 03-01-2010, 09:57 PM
What rear rims are you using that have a 3:5 offset? I have not seen any rims in that offset for the 700XX.
Anyway, if you did use a 3:5 rear rim, you would be 6" wider overall in the rear. The stock 11" rear wheels are about a 5:2 offset. So, if you use a 3:2 offset front, you will only be about 1" wider from stock in the front. I think Douglas wheel makes a 2:4 offset front wheel, so with that you should be about 5" wider in the front. (Stock front wheels are a 4:1.5 offset.)
With that being said, with the above wheels, your 700XX will be around 53 to 54" wide. Not really sure how that would handle.
Almost forgot. The first number of the offset is the inside measurement, while the second is the outside. So 3:2 wheels will make your quad 2" wider overall then 4:1 wheels.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
