Loading ramps for truck bed? - Club700XX - Honda TRX700XX Forum
post #1 of 26 Old 04-05-2010, 09:06 PM Thread Starter
I have a small trailer that I use sometimes to tow my 4 wheeler on behind my truck, but since my driveway is so tight, I usually dont like to take it out because its a pain to back in to the driveway at the end of the day. I bought a set of steel ramps from the dealer, they are very strong and work OK. However, since my F250 is lifted, they are a little scary to go up sometimes. Plus my quad is about 4 inches wider than the ramps. I been looking online at some aluminum ramps.
What are you guys using to load your quad in the bed of your pickup? This thing is just too heavy to lift, especially by yourself. I used to be able to lift the front wheels of my 450R into the bed and push the back up, but the 700 is just too heavy.
2008 Red/Black 700xx EHS Airbox Lid, EHS Tuner, Barkers Full Exhaust, AMR Diamond Plate Graphics Kit, ProArmor Fat Peg Nerfs Powdercoated Black
Diesel700xx is offline
post #2 of 26 Old 04-05-2010, 09:18 PM
I use a winch to load my 700xx.
post #3 of 26 Old 04-05-2010, 09:33 PM
Do you sit to pee as well?
post #4 of 26 Old 04-05-2010, 10:23 PM
ChadH67's Avatar
Send a message via Yahoo to ChadH67
Loading mine is the only part I hate, I tried to find a elevation change or a ditch and still use my ramps. I popped the clutch loading mine the other day and almost landed in the cab of my 45k$ truck I turned green on that one been using the ditch ever since
ChadH67 is offline
post #5 of 26 Old 04-05-2010, 10:27 PM
Yeah I also put an extra set of wheels between the bed and the quad as a buffer in case I wildcat it up.
The Tacoma is a little easier.
post #6 of 26 Old 04-05-2010, 10:31 PM Thread Starter
I really like these extra wide and extra long ramps, but almost $400 after shipping seems like a lot
http://www.discountramps.com/extra-wide-atv-ramps.htm
post #7 of 26 Old 04-05-2010, 10:57 PM
ChadH67's Avatar
I need to start doing that, I didn't think about placing a spare tire or something back there. My wife was watchin when I about landed in the back seat I came down no more than 3 or 4" from going into the cab of the truck
ChadH67 is offline
post #8 of 26 Old 04-05-2010, 11:03 PM
bkelley's Avatar
Do you have an angled driveway? If so, back your truck like 1/4 of the way up the drive and load it that way. I'd suggest getting a pair of wider and longer ramps, too. I can ride my bike into my dad's lifted on 6 foots ramps F350 without problems.
Red '05 TRX400EX:
bkelley is offline
post #9 of 26 Old 04-05-2010, 11:07 PM
ChadH67's Avatar
I have a very steep driveway, That is what I have been doing, that or backing down into the ditch it just makes it so much safer and easier
ChadH67 is offline
post #10 of 26 Old 04-05-2010, 11:12 PM
I do a few different things. When I am using a farm truck (a ranger or s10 usually around home), I just wheelie into the back of it and pick the rear up and pop a nut while doing it. When I have my truck, I use a set of trifold stands that the two outside rungs are covered with a carpet material that I put on there for my snowmobiles to go up so the skis wouldn't hit. But I am lifting my truck soon, so I am going to what I did w/ my old truck. Get two hard wood planks (2x12's) prolly 10 footers, cut them in half, and then use a couple of hinges w/ dome bolts (don't know the exact name but they kind have a mushroom head on one side) that way I can have them go all the way thru, and then just take a strong rod (rebar-whatever is strong and handy), and use a 2-3 foot piece of that on the bottom side for support, so the hinges will be on top. Worked b4 like a champ, and this time I should have a bit better handle on what i'm doing. I also have a tool box in the back of the truck so I don't mess up my cab or back window. And I am doing extra long ramps this time so that I can load my bikes up easier with out the undercarriage hitting b/c of the angle.
