Have fuel have spark but won't start!! - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 03-04-2018, 01:59 PM Thread Starter
I've searched the forum and found quite a few threads with same issue. I've tried everything in those threads which I'll describe next.
I was out riding a few weeks ago and bike started "choking" out. Rode for about 4 hours no problems then all of a sudden when I started giving it gas it would choke out and back fire occasionally then die. Eventually got towed back by my buddy and then the bike started right up and ran fine. Immediately thought fuel filter so I bought a filter off eBay. Replaced and now bike wouldn't start. I checked the injector and didn't seem like much fuel was squirting so I replaced the injector and while I was at it bought the high performance kemco fuel pump and spare plugs. Current plug had great spark by the way, but was pretty dirty. Now, I'm getting plenty fuel squirting through injector but still won't start and have tried all 3 plugs as well. It will however start off starter fluid... thoughts???
zrated512 is offline
post #2 of 3 Old 03-04-2018, 04:09 PM
Quoted: 143 Post(s)
do a compression test . check valve lash
cataway is offline
post #3 of 3 Old 03-13-2018, 03:15 PM Thread Starter
Compression was 105. Went ahead and adjusted valves while I was at it. Rechecked compression and was at 90. Book says if compression is high it's either decompression mechanism or carbon build up. Pulled the cam and took to a local Honda tech and says it looks fine. Where to go next??
