How hot? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 09-20-2018, 05:38 PM Thread Starter
sparky277480's Avatar
Quoted: 7 Post(s)
How hot does an after market header get? I put one on and it got very hot to the point where it started to burn my pants. Just wondering if it normal and I need to adjust my riding. I know I can always put my heat shields on but I would hate to cover up the pipe.
sparky277480 is offline
post #2 of 15 Old 09-21-2018, 05:35 AM
Footy's Avatar
Quoted: 46 Post(s)
I could not deal with all of the heat from the head pipe so I used header wrap.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #3 of 15 Old 09-21-2018, 05:41 AM
/CUDA's Avatar
Quoted: 27 Post(s)
which oil do you use ?
/CUDA is offline
post #4 of 15 Old 09-21-2018, 08:25 AM Thread Starter
Quoted: 7 Post(s)
I use the honda brand oil 10-30.
post #5 of 15 Old 09-21-2018, 08:30 AM Thread Starter
Quoted: 7 Post(s)
So footy urs ran real hot before u wrapped it too. So it's normal to be hot? Did u adjust ur programming at all? I read in here that if it's hot it running lean and to fix it is to adjust the programming for the air fuel mix.
post #6 of 15 Old 09-21-2018, 09:08 AM
Footy's Avatar
Quoted: 46 Post(s)
Mine has the stock head pipe with an FMF muffler. I have attempted to tune it with a programmer. I think it is as good as I will be able to get it. I have considered taking it to ehs but he requires you to buy his programmer.
2013 Husaberg FE350
2008 Honda TRX700XX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #7 of 15 Old 09-21-2018, 09:09 AM
/CUDA's Avatar
Quoted: 27 Post(s)
I run with standard pipe,
initially, when buyed this super atv
the heat was really high,
the leg, always red,
then I removed all the pieces that I considered not fundamental,
quad lost 25 pounds
I increased the air in the filter,
and changed oil with a 10w30 Castrol power, not racing,
but the normal (blend)
However, the heat has decreased a lot,
I no longer feel this annoyance,
I do not know if it's suggestion,
but, I do not think so.
10w30, I think it's not the best,
better 10w40, I will change soon,
10w40 does not lose pressure like 10w30,
when the engine is very hot,
but this is another story.
/CUDA is offline
post #8 of 15 Old 09-21-2018, 09:22 AM Thread Starter
Quoted: 7 Post(s)
quad lost 25 pounds
I would have to try the 10-40 to see if that works on my next oil change.
post #9 of 15 Old 09-21-2018, 09:24 AM Thread Starter
Quoted: 7 Post(s)
I now have the fmf exhaust and header with the programmer by fmf. Uni filter with pre filter lid is off. I might have to wrap my pipe. If it normally runs hot.
post #10 of 15 Old 09-23-2018, 06:56 PM
I have same set up on my bike, but have a spectra open air filter with no air box. My header gets very hot too. Did you ever do the exhaust wrap? Did it help at all? I’ve also noticed mine like to die if running or revving to higher rpms, then letting off of throttle. Have u seen this problem at all on yours? What programming are you running on yours?
Ray Moore is offline
