Currently shopping for a 700xx are there specific things I should make sure to check - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 01-29-2019, 01:02 PM Thread Starter
Deephaven's Avatar
Quoted: 21 Post(s)
Wondering if there are any typical failures on the 700xx. I’ve searched the forum and found these items:
3rd to 4th gear transition - can't find why. I assume maybe this is the failure point in the tranny?
Cam tensioner – listen for intermittent tick
Valve adjustment – idle characteristics ok, not a big deal for me to need to adjust it but can it cause damage if it has been left not done.
Some say the run hot/overheat easy. Is there a way to check for this without a reasonable ride? I couldn’t’ find the cause…outside of too much oil?? Classically it is lean behavior if the radiator is not blocked, no?
Oil in the airbox
Also curious is there a way to check mileage/hours on the machine?
Obviously, I will do the generic checks as well:
Compression / Piston wash / Spark plug
Clutch operation
Fluid condition & inspect for leaks
Air filter condition
Alignment & general inspection for crash damage
Looseness in suspension components on lift
VIN being there and legit
Brake condition
Frame & Suspension condition including CV
Chain tension
Tire & wheel condition – rubbing, signs of bent or neglect
Check cable tensions
Anything else I should be wary of and check?
Deephaven is offline
post #2 of 6 Old 01-29-2019, 01:29 PM
Quoted: 255 Post(s)
I will reply more later when I get home. One thing definitely check is the right rear axle, for the inboard joint play. If that's bad it's going to cost you at least three hundred in parts.
M_Quick is online now
post #3 of 6 Old 01-29-2019, 01:52 PM Thread Starter
Deephaven's Avatar
Quoted: 21 Post(s)
Thanks, no hurry I won't be going to see one for at least a week.
post #4 of 6 Old 01-29-2019, 03:41 PM
Quoted: 255 Post(s)
To date I've had zero issues with either of my transmissions. Although my original blk&gry quad has always since day one been difficult to find neutral. Both are still on the original cam tensioners. As far as running hot, it's not that they over heat. There is just some extreme heat that comes off the exhaust header, especially if your running at low speeds, like 1st and 2nd gear only. Speaking of gears, the stock 700xx will barely hold it's own while idling. That's why a lot change front sprocket to a 13t. only oil I get in my air box, is from over oiling the filter, lol. And no there is no way to check the mileage or hours, unless someone installed a hour gauge day one. Hope this helps.
post #5 of 6 Old 01-29-2019, 04:37 PM
Quoted: 143 Post(s)
this is the only problem I have had with the transmission
cataway is offline
post #6 of 6 Old 01-29-2019, 10:33 PM Thread Starter
Deephaven's Avatar
Quoted: 21 Post(s)
Appreciate the heads up. I searched the forum like crazy but didn't find much for systematic problem areas.
