Axle question? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 03-25-2019, 04:33 PM Thread Starter
Axle question?
I recently had a right rear axle boot rip so I tried to pull the axle out and I can’t do I just need to pull hared I’m just trying to make sure before I damage the carrier
Blake Newby is offline
post #2 of 7 Old 03-25-2019, 07:23 PM
Quoted: 143 Post(s)
yeah getting it out can be a pain . I had to get a wedge in it then shock it really hard . you are fighting a snap ring that has to compress which is likely rusted . keep at it
cataway is offline
post #3 of 7 Old 03-26-2019, 05:55 AM
Footy's Avatar
Quoted: 45 Post(s)
Get yourself a cup of java and then sit down and read this:
https://www.club700xx.com/vb/8-motor...e-removal.html
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #4 of 7 Old 03-26-2019, 03:18 PM
Is there a clip that has to be removed before pulling axle out. Just got my 700 and want to grease the splines before they wear out. Tia
Canuckhd is offline
post #5 of 7 Old 03-26-2019, 05:35 PM
Quoted: 255 Post(s)
No not before, but there is a circlip on the end of axle.
post #6 of 7 Old 03-26-2019, 06:42 PM
So basically just remove wheel,shock and knuckle then pull cv joint out of diff?
Canuckhd is offline
post #7 of 7 Old 03-27-2019, 05:39 AM
Quoted: 255 Post(s)
I think you also need to unhook the sway bar. And it's more of a pry apart, than pull.
