Testing some plastic cleaning procedures... - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-25-2019, 02:11 PM Thread Starter
Hey everyone, this afternoon I decided to try working on my plastics. I just bought this 700xx and the plastics are really bugging me. I know they are probably in normal condition for the year but I’m really meticulous with my stuff and I like my “toys” to look good! So what I did was clean the rear fender area quick. I then buffed the fender using Meguiar’s ultra cut compound. I then followed that by waxing and buffing that off. Overall it came out ok I think and I guess I’m just going to have to live with the deep scratches and gouges unless someone else has some other method to try... so here are the results..
File Type: jpg 8EBD924A-1E9B-43A8-B8C2-A5790758947E_1556219311927.jpg (42.8 KB, 16 views)
File Type: jpg 4709065F-5C8C-4BF0-B561-6C9F2721B057_1556219342166.jpg (40.8 KB, 16 views)
File Type: jpg F3A64941-8528-4B55-B2AB-28C2126B4E93_1556219382293.jpg (36.0 KB, 15 views)
fonz3482 is offline
post #2 of 6 Old 04-25-2019, 10:12 PM
Deephaven's Avatar
Quoted: 21 Post(s)
Looks good. Just bought one myself and had planned on doing the same. Did you find black touch up paint that matches the painted parts?
Deephaven is offline
post #3 of 6 Old 04-26-2019, 02:09 AM Thread Starter
I haven't looked into black touch up paint yet. When you say painted parts are you talking about the frame and a-arms? I didn't notice any other painted parts that I can recall. I did see some areas on the frame that could use some touch ups and my lower a-arms the powder coat is worn off the bottoms of the arms pretty good. I kinda decided last night to tear the machine down and give it a thorough cleaning.. I know it may seem nuts to do, but that is what I have done to any used machine I've bought in the past. It allows me to give the machine a good check over while cleaning it up and improving its appearance at the same time.
fonz3482 is offline
post #4 of 6 Old 04-26-2019, 08:29 AM
Deephaven's Avatar
Quoted: 21 Post(s)
Yes. Same exact situation here. Bottom of the a arms are both longer powder coated and a few other spots on the frame and such. Last night I washed the gas tank and areas that you can't see once the plastics are on. Mine is in pieces to check out completely as well. New to me, which means I don't trust the condition until I have wrenched on it. The other positive about disassembling is that it makes it way easier to know what to carry for tools.
post #5 of 6 Old 04-27-2019, 01:28 AM Thread Starter
That is exactly the way I like to go through and atv when I buy it. I pull all the plastics so I can fully see everything, I give the whole atv a good once over and before it goes back together everything gets cleaned to my best abilities. For the black powder coated wear items I had a decent idea. I was thinking of running a straight line of tape right across the whole lower control arm. Then sand, prime and paint the spot that wears out with spray on truck liner.... that stuff is a flat or satin black and it may take a pretty good beating. Otherwise it just have to be powder coated again. So for now it think I may try the bedliner thing because I’m not sure I want to dissemble it and send stuff out to the powder coating place. That is more of a winter project.
fonz3482 is offline
post #6 of 6 Old 04-27-2019, 07:28 AM
Deephaven's Avatar
Quoted: 21 Post(s)
Ha, mine will hit the powder coater in the winter as well. Not now! Just trying to decide what other pieces to add to it when it goes. I like the bedliner idea, but not sure I want to pull the arms to do that. Could do it in place I suppose, but I somehow always miss masking something when I try that and get over spray on exactly what I don't want to even when it is covered nicely.
I have some Polaris flat touch up paint which I bet matches "good enough", but still would rather find a local option. Have a bunch of other things to finish first, but will surely post some pics of the transition when I get it closer.
