Handlebar mounted GPS? - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 05-21-2010, 01:34 PM Thread Starter
Anyone know of any or any ideas? Need it to survivue the dunes
Captamer71 is offline
post #2 of 14 Old 05-21-2010, 01:45 PM
Member skier can probably help you out... he made a mount that looked real neat...
post #3 of 14 Old 05-21-2010, 02:40 PM
Garmin makes one and you can buy it on Amazon. Look under handheld gps accessories
post #4 of 14 Old 05-21-2010, 03:21 PM
J Caster's Avatar
Our team uses the Garmin Legend HCX. You want to make sure if you mount it to your quad you protect it from vibration. The problem with the hard handlebar mounts is that they allow the vibration to travel up to the GPS. We use a thick foam barpad from Renthal and cut out an area for the GPS and hold it in with zip-ties. The foam soaks up the vibration and the GPS keeps on working.
J Caster is offline
post #5 of 14 Old 05-21-2010, 04:03 PM
gps
Im using a garmin 60CSX ram ball mounted to handguards.
katfish52 is offline
post #6 of 14 Old 05-21-2010, 04:48 PM
That's the one I use and it does turn itself once in awhile due to vibration since I'm using their clamp.
post #7 of 14 Old 06-11-2010, 06:53 PM Thread Starter
I got a garmin 60csx Trying figure out what mount I wanna use. I like the idea of the foam pad thanks J caster, maybe also 550 cord it to handlebars incase it somehow slips out?
post #8 of 14 Old 06-11-2010, 08:52 PM
Have heard nothing but good things on the Ram mounts.
2006 Raptor 700
post #9 of 14 Old 06-12-2010, 09:11 PM
I have a Delorme Gps and use a handlebar mount for mapping pipelines and such with no problems.
silliestdaddy is offline
post #10 of 14 Old 06-13-2010, 08:20 PM
trizz's Avatar
http://www.ram-mount.com/Products/GP...5/Default.aspx
trizz is offline
