Need plumbing advice! - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 06-14-2010, 12:02 PM Thread Starter
I got a question for any plumbers or handymen/women. Can I use galvanized pipe in for my shower? I am trying to replace the shower faucet because it was old and leaking and I noticed there was galvanized pipe in the wall running to the shower? I thought it should have been copper but I'm clueless so I am trying to find out before I get it all buttoned up. Should I run copper, PVC, or is it ok to use the rusty galvanized pipe that was already there?
post #2 of 16 Old 06-14-2010, 12:22 PM
Tory trx's Avatar
I would use copper if you can. I have never seen galvanized pipe used in the shower. I would assume its not correct. If you are not comfortable with soldering the copper pipes, you could always get the shark bite fittings in home depot or lowes. But if I were you, since you have it opened up already, I would change the pipes to copper. Better to be safe than sorry.
Tory trx is offline
post #3 of 16 Old 06-14-2010, 12:33 PM
If you are only wanting to replace the shower fixture itself... do that. Galvanized pipe was to code in old homes and is still OK to use. You save money only replacing what you need to. I run a facility that has 10 older homes and they all have galvanized pipe throughout. I only replace the galvanized IF there is build-up inside the pipe that restricts the flow or if the pipe is damaged in other ways.
post #4 of 16 Old 06-14-2010, 01:22 PM Thread Starter
Ok thanks, parts of it are PVC and the other is galvanized? I've tried my hand at sweating copper lines before and it wasn't pretty! I noticed the pipe that the shower head connects to has threads on it? How would I connect a copper line to that? Same with the faucet?
post #5 of 16 Old 06-14-2010, 01:46 PM
Superswire's Avatar
Just find someone with a pex tool, get yourself some pex from lowes and some adapters, it's plastic, flexable and lasts forever, no fires, no leaks...nothing
Superswire is offline
post #6 of 16 Old 06-14-2010, 02:15 PM Thread Starter
What will I mount my shower head too? I'm working out of the access panel?
post #7 of 16 Old 06-14-2010, 02:16 PM
I love sweating copper, I find it enjoyable, which I know is weird. But I would only replace what you need to unless money doesn't matter as much (also depending on how long the pipe is and everything).
post #8 of 16 Old 06-14-2010, 02:32 PM Thread Starter
It's just the pieces of pipe from the valve to the shower head(galvanized) and the piece from the valve to the part where the tub fills out of?(alsogalvanized) but thenpipe coming from under the house is PVC?
post #9 of 16 Old 06-14-2010, 03:44 PM
+1
Pex makes a plumbers job so much easier, but for some reason they still charge the same for labor.
NineLivez2Go is offline
post #10 of 16 Old 06-14-2010, 06:08 PM
if u use copper it may react to the galvanized. id use pvc or just replace the whole thing with copper
