GPS run - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 08-28-2010, 04:43 PM Thread Starter
Gumpus22's Avatar
GPS run
Just made a GPS run and came up with 76.7mph. That surprised me a little. I knew it was fast but didn't expect that. Especially stock. It had a little more, I hadn't floated the valves yet, I just ran out of road. LOL
Gumpus22 is offline
post #2 of 6 Old 08-28-2010, 06:21 PM
av8r's Avatar
My 1992 Polaris Indy 500 once clocked 833 MPH across a frozen lake on my Garmin GPS. GPS is not always accurate. Having said that, it sounds like your speed isn't beyond the realm of possibility.
av8r is offline
post #3 of 6 Old 08-28-2010, 10:50 PM
76.7 is very realistic, even stock it will haul on top. 82.7 was the fastest I clocked mine stock, but that took alot of road. If you are ever worried about the accuracy of your GPS, just do a couple runs for comparison. It will not be consistently wrong.
post #4 of 6 Old 08-29-2010, 03:59 PM
VelociRaptor's Avatar
By what Ive seen the 700 Raptor is low to mid 70s and the XX is mid to high 70s.
Bo White
205-886-7043
VelociRaptor is offline
post #5 of 6 Old 08-29-2010, 04:45 PM
Will the Raptor hit the rev limiter in 5th stock, or does it quit pulling? The 700XX just quits, even with 13T and big 3 I can't get it to hit it.
post #6 of 6 Old 08-29-2010, 04:52 PM
TRX700XXX's Avatar
I'm pretty sure I read in a dirtwheels it just stops pulling.
TRX700XXX is offline
