hauling 700xx on rear end - Club700XX - Honda TRX700XX Forum
post #1 of 23 Old 09-21-2010, 02:13 AM Thread Starter
just wondering why the manual says they dont recomend hualing it standing up. has any one hauled this way and noticed any problems i cant see any problems other than if you didnt shut off the fuel.
z400 is offline
post #2 of 23 Old 09-21-2010, 03:15 AM
b.courtney_700xx's Avatar
oil, as well as all other fluids, will drain to the back of the motor if your "new oil level" is above a overfill valve or any path of escape you may dump your oil. and if you do not realize it you will be an accomplise in xx homicide. plus you may just get oil in places you dont want it.
2008 trx700xx
dg steel series nerf bars
13t renthal
3D powertip
razrs on her feet
b.courtney_700xx is offline
post #3 of 23 Old 09-21-2010, 03:45 PM
I know Wayne Matlock will haul his parts quads this way from time to time during a race. You need to block off the breather line, or else oil will drain out of it, alot of oil. I think Wayne just uses some type of clamp to pinch the rubber line. Other then that, I don't think he has had a problem.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #4 of 23 Old 09-21-2010, 03:54 PM
Xstriker's Avatar
I stored by buddy's machine in my garage. I noticed a huge oil spot on the floor, we think it was the crank case breather leaking. when we changed the oil the next day not much came out. I won't be storing his or my machine on end ever again.
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #5 of 23 Old 09-21-2010, 04:30 PM
av8r's Avatar
Hmmm..I've stood mine up to work on it a few times and nothing leaked out and nothing went BANG when I ran it.
av8r is offline
post #6 of 23 Old 09-21-2010, 06:42 PM
Same here, my thoughts exactly. Maybe my oil was too sludged up to drain out the line...
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #7 of 23 Old 09-21-2010, 07:54 PM Thread Starter
i hope it will be ok because that is the only way i can fit it in my toy hauler with our rhino and i am veryyyy sick of driving our rhino. so what breather needs to be blocked the crank case or the one that goes into the air box. one other question what makes the 700xx differant from the other sport quads cause my z400 had no issues hauling this way
z400 is offline
post #8 of 23 Old 09-22-2010, 06:38 PM
You'll lose abit of oil , comes through the breathers on the head and tranny. Depends how long. Over night it is quite a big puddle!
post #9 of 23 Old 09-22-2010, 09:31 PM Thread Starter
so if i guy was to just kink and zip tie them it should be good till you get to were your going. i guess ill cross my fingers.
z400 is offline
post #10 of 23 Old 11-17-2010, 09:18 AM
Did you ever figure out what breather needed blocked? I need to haul mine like this for a trip soon.
Tom
08 Outlander 800
