Little trick I learned - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 09-30-2010, 12:03 AM Thread Starter
Gumpus22's Avatar
I'm probably the only one that hadn't found this out until recently. I'm sure Baxter and the others that race alot already know but I will post it anyway.
When you stall the old girl you can slide the thumb switch to off then back to run and she will fire right up when the warning lights go out. If I don't do this mine is real hard to restart and usually coughs and spits for a few seconds when it does start back. IDK if this resets the pcm or not but it does run the fuel pump again just like a cold start. Seems to be the ticket on mine anyway.
Hope it helps someone sometime.
Yes I am a pirate..200 years too late... J. Buffet
08 Black and Grey
DG GNCC II Front Bumper
13T SuperSprox
Kenda Kutter 22s all around
Uni
Rest is stock for now
Gumpus22 is offline
post #2 of 10 Old 09-30-2010, 02:53 AM
I too have had the hard restarts.........Will definitely be trying this. Thanks for the info.
Cummins19
CUMMINS19 is offline
post #3 of 10 Old 09-30-2010, 08:00 AM
av8r's Avatar
Huh....I've never had the hard restart issue. Have you adjusted the valves on this?
av8r is offline
post #4 of 10 Old 09-30-2010, 08:41 AM
never had this issue either
08 Honda 700xx
Installed
Britalican is offline
post #5 of 10 Old 09-30-2010, 09:15 AM
post #6 of 10 Old 09-30-2010, 11:15 AM
I've only really had this problem when I race. Something about like going around a corner w/ higher RPMs, letting the engine die down and then going to hit the gas or something she just goes down once in a while LOL. I learned this trick two winters ago, and I figured it helped starting easier b/c it is turning the pump on and off. It doesn't work everytime though. The sputtering that you guys haven't noticed is weird, doesn't happen everytime on mine, but probably 75% of the time, just takes probably 3-5 extra seconds to start.
post #7 of 10 Old 09-30-2010, 04:34 PM
95% of the it is ok starting , the 5% is a real bugger to get her started.
I dont have the thumb switch but I have put the idiot lights back on for the last race . I'll try it by switching off at the key and let you know !
post #8 of 10 Old 10-01-2010, 08:23 AM
trx700's Avatar
I tryed the on and off switch last night and it did not make a differance for me. I will keep it in mind incase I have problems. Good info.
2008 Black & Red TRX 700XX
trx700 is offline
post #9 of 10 Old 10-01-2010, 06:35 PM
yeah when i stall mine it takes a extra 1 or 2 strokes to start
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #10 of 10 Old 10-02-2010, 10:05 PM
Rith's Avatar
Went to sandlake today and killed it one time going down a bowl. I remembered your post and it started first try after flipping the switch. Not sure if it would have taken longer otherwise, but still thanks for the tip
Rith is offline
