Cargo Trailer Conversion - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 11-05-2010, 05:26 PM Thread Starter
Looking for some helpful input or someone to point me in the right direction with adding power to my cargo trailer. I want a basic 20 amp rv hookup along with being able to run things with a generator. I need to know what I need to make this happen. All I'm trying to run is a mini fridge, some lights, 1.8gpm water pump and maybe a microwave.
John
NineLivez2Go is offline
post #2 of 6 Old 11-05-2010, 06:25 PM
It's pretty straight forward. All the equipment can be found at your local home center.
First off, you'd need a breaker panel. Since you want a microwave, I'd suggest going with 2 15 AMP circuits.
What you would do is, get an "RV" cord and run the wires from that to the "Hot", "Neutral". and "Ground" terminals in the breaker pannel. The "RV"cord should be capable of providing 30 amps.
Then run your wiring to the outlets.
Last step is to install the circuit breakers.
Plug the "RV" cord into the generator.
sgip2000 is offline
post #3 of 6 Old 11-05-2010, 06:38 PM Thread Starter
That does seem pretty straight forward but what if I need to run on battery power?
post #4 of 6 Old 11-05-2010, 06:45 PM Thread Starter
Is this over kill?
post #5 of 6 Old 11-05-2010, 07:24 PM
Originally Posted by NineLivez2Go View Post
Is this over kill?
Yes.
sgip2000 is offline
post #6 of 6 Old 11-05-2010, 07:27 PM
You'd need something like this: http://www.wfcoelectronics.com/index...d=56&Itemid=77
That will let you run 12V accessories off of battey or A/C. It will also charge your battery.
It will NOT run 120V A/C plugs off of the battery though. You'd need an inverter for that.
sgip2000 is offline
