Remove me from Spokeo - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 01-20-2011, 05:56 PM Thread Starter
Well! As usual there's always some web site that will sell your info so if you want to remove yourself from that web site;
http://www.spokeo.com/
type your name under search and if you see yourself under your new or old address, click on the link then go to the main link above....where you usually type www.andsoon
copy that link then go to the bottom of the page and you'll see "privacy" on the lower right corner and click on that link and paste the previous copied link under the url and finish typing the info below and submit. You'll receive an email and just follow the instructions which is real easy.
Don't forget to check all the states that you lived in the past cause I found myself under CA, TN and PA.
post #2 of 2 Old 01-22-2011, 10:22 PM
av8r's Avatar
and you believe that by doing this they're really going to pull your data? Do you understand how spokeo works? Spokeo is an aggregator. They don't store data...they scrape it from other sites and present it. Your data is online forever. Nothing you can do about that. Be careful what you say online...it's there forever.
av8r is offline
