More BRAP! less CRAP! - Club700XX - Honda TRX700XX Forum
post #1 of 31 Old 03-23-2011, 11:01 AM Thread Starter
Qaz
Was wondering what things can be removed or changed to shed some weight.
allready removed parking brake, installed aftermarket levers, run 20" rears and 21" fronts. What else can i do??
Qaz is offline
post #2 of 31 Old 03-23-2011, 11:55 AM
Aftermarket chains can be lighter. different sprockets can be lighter. Shocks can be lighter and make for better handling. Run less gas from the get go (if you are staying pretty close to your truck and not venturing too far off). Could take some of the plastics off. Everything else, ask BAXTER. I think he probably has the lightest one on here.
post #3 of 31 Old 03-23-2011, 12:41 PM
I shed 8lbs by switching to the fox shox. Aftermarket exhaust will save you some weight also.
post #4 of 31 Old 03-23-2011, 04:08 PM
TRX700XXX's Avatar
Aluminum handlebars, aftermarket steering stem
TRX700XXX is offline
post #5 of 31 Old 03-23-2011, 04:26 PM
Quoted: 5 Post(s)
A good diet and exercise program..........................sorry had to!
Snowdog is offline
post #6 of 31 Old 03-23-2011, 05:33 PM Thread Starter
Qaz
anyone removed there lights or have a picture of lights removed prolly an ugly bia without headlight. but ill bet thats a few pounds and im blind as hell so dont ride at night could just put that tinted cover in the headlights place i guess
Qaz is offline
post #7 of 31 Old 03-23-2011, 05:43 PM
08700xx's Avatar
I removed the head light and it was too ugly so I put it back on. I cut all the front and side plastics off mine. There is a lot of after market parts you can buy to drop weight but it gets expensive fast.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #8 of 31 Old 03-23-2011, 07:05 PM
You aint for off though!
By my reckoning I have the third lightests.
08700xx has the second lightest.
The lightest is by another member , who I am still waiting pics from. (J)
post #9 of 31 Old 03-23-2011, 07:07 PM
traitor08's Avatar
So whts done baxter
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #10 of 31 Old 03-23-2011, 07:19 PM
Depends on how mechanically minded you are. Not meant to be an insult but I have questions by pm and I explain and they reply "wheres that located".
