Detailing tip! - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 04-04-2011, 08:03 PM Thread Starter
Detailing tip!
So i get a lot of crap about how my bike always looks so new and shiney. Well i want to share with you guys a product that i have been using to keep my bike looking new.
It's called Maxima SC1 Clear Coat. All you do is clean your bike, spray the plastics down with this product and let it sit for 30 seconds. This allows it to be absorbed into the pores of the plastic. Then buff off to a shine. Your plastic will look shiney and almost wet. It doesn't leave a greasy residue or anything like that. It makes water bead up like wax would and prevents mud and dirt from sticking to your plastic and leaving them dull looking.
I use it every couple of rides to keep that nasty clay mud from sticking to everything.As you can see in my picture thread it works great. Smells good too!
post #2 of 7 Old 04-04-2011, 10:03 PM
is that what you use? i thought it was like that from you not riding it! lol, jk
post #3 of 7 Old 04-04-2011, 10:10 PM
DL700's Avatar
PLEXUS is the BOMB too
DL700 is offline
post #4 of 7 Old 04-04-2011, 11:07 PM
08700xx's Avatar
Lemon pledge
(DL700)
Jody (Boost Addict)
08700xx is offline
post #5 of 7 Old 04-04-2011, 11:18 PM
92K1500's Avatar
I think he just leaves it sitting in the garage all the time.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #6 of 7 Old 04-05-2011, 05:11 PM
TRX700XXX's Avatar
Originally Posted by 08700xx View Post
Lemon pledge
TRX700XXX is offline
post #7 of 7 Old 04-05-2011, 05:38 PM
trx tas's Avatar
+1 for the maxima sc1
trx tas is offline
