GoPro Question - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 04-20-2011, 01:24 PM Thread Starter
Xstriker's Avatar
GoPro Question
I have my gopro currently moutned on top of my helmet, I don't like not being able to see the handlebars when I playback the video. Do any of you guys have a picture of a GoPro mounted on the side of your helmet? I'm just debating on the best way to put it on, and since you can't really move the mount after it's stuck I wanna get it right the first time.
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #2 of 11 Old 04-20-2011, 02:00 PM
i got mine on the side. Cause i wanted to get my bike in the frame. I can take a picture later tonight after i get off work.
post #3 of 11 Old 04-20-2011, 03:07 PM Thread Starter
Xstriker's Avatar
That would be awesome.
08 TRX 700XX
EHS Programmer
11/16 L8ton Swaybar
Xstriker is offline
post #4 of 11 Old 04-20-2011, 03:20 PM
TRX700XXX's Avatar
You can take off your visor on your helmet. It will probably look weird but at least you can see the handlebars then.
TRX700XXX is offline
post #5 of 11 Old 04-20-2011, 04:42 PM
iNick's Avatar
Mounted on the front side of a chest protector (up high) is how my buddy has his, you can see the bars and trails.
iNick is offline
post #6 of 11 Old 04-20-2011, 08:37 PM
bdr455's Avatar
Send a message via Yahoo to bdr455
I agree mine is on the side too.
700xx
BruteForce 650i
400 Sport Polaris
300ex
bdr455 is offline
post #7 of 11 Old 04-20-2011, 08:42 PM
cant u use a goggle strap mount to see what it looks like on the side? idk about go pro, i know the contour hd can mount to the goggle strap.
08 Honda 700xx
Installed
Britalican is offline
post #8 of 11 Old 04-20-2011, 09:17 PM
I have the HD gopro. It is bigger than the regular gopro. You can watch my video's in the video section to see what this mount looks like.
[IMG][/IMG]
[IMG][/IMG]
post #9 of 11 Old 04-20-2011, 09:39 PM
that mount doesn't get in the way of your goggle strap?
08 Honda 700xx
Installed
post #10 of 11 Old 04-20-2011, 09:49 PM
Nope
