pw80 help - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 07-28-2011, 05:39 PM Thread Starter
Queenz700XX's Avatar
pw80 help
ok so i let my friend try out my pw80 and he took a nice fall on it and now the bike will not move when i shift it into each of the gears its a semi auto 3 speed. is it the clutch that broke or something else . any help or advice would be much appreciated. thanks
2008 TRX 700xx
PCV
FMF Powercore 4 full exhaust
K&N Intake
Modified Airbox
13t Front Sprocket
Billet Gas Cap
rear- 22x11x10 razr2
front- 22x7x10 razr2
ITP SS112 MACHINED RIMS
ALBA PRO ELITE NERFS
l8ton 11/16 sway bar
Queenz700XX is offline
post #2 of 3 Old 07-28-2011, 09:21 PM
Try jacking it up and see if it tries to move the tire at all. If it was a Honda I would try adjusting the manual clutch on the right case. The linkage that disengages the manual clutch sounds suspect, but if that was the case it should feel really odd when you shift, it would shift really easy compared to usual. I really don't know how the PW80 manual clutch disengages though. If no luck there, I would take the right cover off and look at both clutches.
post #3 of 3 Old 07-28-2011, 10:14 PM Thread Starter
it shifted normal but i will try that tomorrow and see what happens. it looks like she's coming apart for the first time.
2008 TRX 700xx
PCV
K&N Intake
Modified Airbox
13t Front Sprocket
Billet Gas Cap
