trx450r shocks - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 11-02-2011, 10:28 AM Thread Starter
trx450r shocks
does anyone know if the trx450r front shocks fit the trx700xx..thanks in advance
elioquadsport is offline
post #2 of 15 Old 11-02-2011, 12:29 PM
Yes they do
post #3 of 15 Old 11-02-2011, 12:45 PM Thread Starter
Originally Posted by Red-N-BlackXX View Post
Yes they do
thanks for the reply...do they alter the ride height ?
post #4 of 15 Old 11-02-2011, 01:08 PM
i think the front will sit lower due to the 450r shock is about a inch shorter.
post #5 of 15 Old 11-02-2011, 01:15 PM Thread Starter
mmmm....would rather keep the height the same
post #6 of 15 Old 11-02-2011, 02:20 PM
I tried the 450r shocks . I seem to remember they were 1 1/2" shorter.
post #7 of 15 Old 11-02-2011, 02:26 PM Thread Starter
need a upgrade but want to keep the same ride height to get over the ditches up here..seen a set of elkas on e bay that were listed as 505mm long,dont know if he meant from bolt to bolt or not but is a good wee shorter than the 700
post #8 of 15 Old 11-02-2011, 04:20 PM
The 505mm (19 7/8") will be LT fronts or equivilant to. The Elka st1 (stock length) I have measure 450mm (17 3/4"). Also they have been on Ebay for a while !
post #9 of 15 Old 11-02-2011, 04:39 PM
headscratch
not to change the subject, but can you use the LT shock with the stock a arms or do you got to use the 17 3/4 one with the stock a arms?
post #10 of 15 Old 11-02-2011, 05:04 PM
The max you can go with the stock a-arms is about 18 1/4" and that puts alot of bind on the ball joints.
